Etch primers
Richie Wignall
Etch primers
Post by Richie Wignall »
Hi Guys
Can anyone recommend a good primer? I have been using U-Pol Acid 8 etch primer aerosol, but the place I have bought it from in the past has gone under. I think I paid about £8 for it last year. Now phoning around local companies but they are few and far between, one company wants £18 for an aerosol. Is there any good primers that I can use on the KT and also spray with a compressor, and will not flake off.
Hope this all makes sense.
Richie
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Hi Richie, I use U-Pol acid etch, and buy it from Halfords
regards
Jeff
Has liked: 1480 times
Been liked: 1685 times
Ditto getting it from Halfords, though they only seem to keep one can on the shelf at a time. It was £10.99 a can last time I bought some.
I use their online ordering system to find out which local stores have it in stock, then go and wipe them out :twisted: :lol:
I've got quite a stock now - I just hope it doesn't have a use by date :oops:
Matthijs Dijkstra
Been liked: 2 times
Post by Matthijs Dijkstra »
Hi Richie,
Here is another tip! Sand blast (glass pearl) all the alluminium parts before using the etch primer. The surface of the alluminium plates gets a little rough (matt) so that the primer even more sticks to the metal. I have good results with this method.
Hope this helps,
Matthijs
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Richie,
Try and find a good auto paint shop near you. They will do an aluminium etch primer for a spray gun but you may find it a little expensive, and you will have anough to prime a dozen or more KT's!!
Allan Richards
Richie Wignall
Hi Guys
Thanks for the help, been halfords :? is like looking for hens teeth :lol:
Can get the acid 8 in a 1ltr can, but didnt know if you could thin it to use in the sprayer.
:roll:
Richie :wink:
P.S. I HAVE NOW BEEN ON HALFORDS ON-LINE AND RESERVED 2 CANS. THANKS FOR EVERYONE'S HELP.
RICHIE
