1/6 scale v8 flathead
Medard Winants
Has liked: 3 times
Been liked: 2 times
Post by Medard Winants »
Is there somebody who try to build a 1/6 scale v8 flathead engine into his universal carrier?
I saw this engine on the web and thought that it would be a perfect option to make my carrier more realistic.
https://www.enginediy.com/products/ciso ... that-works
Jerry Carducci
Has liked: 3 times
Been liked: 1120 times
Re: 1/6 scale v8 flathead
Post by Jerry Carducci »
You'll need some sort of clutch mechanism. Not certain the existing UC axle would be happy with 3 1/2 HP.
They mention optional cast iron piston rings but don't mention if they use steel or cast iron cylinder liners -an important point to consider.
There's another Asian manufacturer of similar 4cycle multi cylinder engines that initially used either ABC or Al-Si cylinders that I would
have little confidence in for extended wear life.
As many have pointed out to me over the years you'll never attain the throaty sound of the full sized machine with a tiny engine; even
a tiny 4 cycle engine...
Yes I have quite a bit ofexperience with ICE powered models...albeit mostly 2 strokes.
Last edited by Jerry Carducci on Sat Dec 09, 2023 3:40 pm, edited 1 time in total.
Has liked: 1040 times
Jerry it’s similar to blank firers - yes they make a bang but nothing like the real thing. Good point.
Been liked: 1844 times
Make sure you have a good speaker and a quality amp. Like Jerry said you'd have to re-engineer the whole model drive system.
Go EV, like garlic bread, it's the future!
IC power is a nightmare in an enclosure even a just a single cylindered one and that will sound like a lawn mower if your lucky.
There are a lot of fakers on Youtube, check out this clip for the real world.
How to get parted from your hard earned. :lol:
Medard Winants
Has liked: 3 times
Been liked: 2 times
I know the sound isn’t like the real thing, especially the nitro version the gasoline version sounds better. But that’s with every rc model including the way the models drive versus the real thing. But what I ment was the visual accuracy that also works for real. I think that would be real eye catcher.
I understand what you mean especially if you think there's enough space to fit a scale IC motor.
Check out Phil Woodard's build, "David's carrier build" a fantastic Universal Carrier with a 1/6 scale dummy metal flat head V8 with accessories, none of the downsides of the IC motor.
He's got the look and the flexibility of electrically powered model too. :mrgreen:
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi Medard,
There are some cheaper options. This was done from a very good set of purchasable .stls on Cults and printed on an Ender 5. I have added a bit more detail as always :-)
As its all printed in separate components you could probably modify quite easily to hide a motor.
Dave
www.armorpax.net
Has liked: 2282 times
Been liked: 7196 times
I have a brand new mostly metal flat head still boxed if you want it.
Screenshot_20220630-210751_Samsung Internet.jpg (97.11 KiB) Viewed 12186 times
Medard Winants
Has liked: 3 times
Been liked: 2 times
Phil Woollard wrote:
Sat Dec 09, 2023 7:55 pm
Oh sounds interesting, what do you afk for it?
Medard Winants
Has liked: 3 times
Been liked: 2 times
Dave Dibb (Armorpax) wrote:
Sat Dec 09, 2023 7:17 pm
Hi Medard,
Dave
Hi Dave,
Thanks for your reply. I have a snapmaker artisan so it’s an option indeed.
