Tiger 1 parts
Has liked: 2282 times
Been liked: 7196 times
Tiger 1 parts
I'm currently printing Tiger 1 fuel tanks, radiators, fan ducts, fan housings, fan gearboxes, the fan center boss ( to attach to the pcb fan center) and the fan gearbox mounts.
If you are interested in the set please email ptwoollard64@hotmail.com
Re: Tiger 1 parts
Update on the parts, one side of the upper engine bay kit is now printed, very nice prints using standard print quality, if you can get this right it sure cuts down on print time, although its still painfully long print times for these large pieces.
I generally use a reasonable high level of infill support structure, this makes the piece very strong indeed, you could quite easily stand on this without any damage, the internal support structure also affects the final top layer finish quality. Another benefit of the dense support structure is that the part feels heavy and robust.
And that's how they fit snuggly together.
Re: Tiger 1 parts
Nearly done one set, the last fan housing is now on the print bed.
I just love the support structures , remember the early versions ( not that long ago) that took an age to remove with hours of cleaning up to do, not anymore as just a gentle tug and it all pulls away.
And all together
And all together
Re: Tiger 1 parts
Due to so much interest I've decided to offer, my Tiger1 half engine, Panther half engine and the King Tiger half engine.
Initially these will be supplied assembled and in primer, with a reasonable amount of detail but scope for further super detailing if you wish to do so.
I've made one important upgrade, the air filters will have removable lids with a functioning oil bath that can be filled with either oil or coloured resin.
PM me for my email.
Although this is a full engine example it shows basically what you get
Panther and King tiger cyclone air filters shown here
Raw half engine parts straight from the print bed.
I'm busy printing the various smaller parts like the fan drive outlet shaft stubs and the thumb screws
Tim Carr
Has liked: 2551 times
Been liked: 96 times
Re: Tiger 1 parts
Post by Tim Carr »
Looks Very Nice!
Good Job Phil!
Later Tim
Tampa Bay, Fla area USA.
Re: Tiger 1 parts
A quick update on the half engine.
My printer is working very hard and it's printing very well indeed, these simple cyclone air cleaner handles can be problematic but all is well.
It's a little tricky getting the large parts aligned , you just have to measure and measure again before you bond. I really need to make a jig, I will put together a simple build log with variations for the different engine types.
Lots more detail for this Panther half engine I'm putting together right now.
Re: Tiger 1 parts
The Panther half engine is slowly coming together, there are so many parts involved. A big thank you to Vince for helping out.
I think it's important to have the cyclone air filter assemblies demountable, when it's all installed in the engine bay you are able to lift out the covers as if your crew is carrying out a service.
Re: Tiger 1 parts
More progress as the detail parts start to really bring it all together.
Primer for everything
These extension springs are perfect for the HT lead conduit
Nice
Nice
Stippling the rocker covers
Almost ready for the exhaust headers
Pin drilling the various plumbing fitting mounts
Beautiful exhaust shields
More accurate air cleaner handles
The throttle body swivels x8
Throttle body swivels in place ready for the linkages
Fits extinguisher and water pipes starting to take shape
Re: Tiger 1 parts
Well this one's now done and will be off to the customer very soon.
Today's small detail parts to fit  then she's done.
That's enough carb linkage for now
The throttle linkage done but you can still demount  the whole carburetter assembly if you wish
Oh and the exhaust header shields to as well.
Left and right lettering done
The exhaust extensions will be included in case the owner wishes to go that little further.
Robert Tanzer
Has liked: 1131 times
Been liked: 990 times
Re: Tiger 1 parts
Post by Robert Tanzer »
Well done Sir.
I take of my hat for you and your nice work.
Robert
