Steve,s Chieftain rebuild
- Has liked: 8 times
- Been liked: 701 times
Over the last few weeks I have started with my Chieftain rebuild, this is a tank that I bought ready built a year or so ago.
The plan is to do a complete strip down and rebuild.
Being somewhat behind other builders allows me to see where the necessary mods and upgrades are needed which reduces the amount of research required.
I have initially started with the turret and been working on it when progress on my Panther build stopped while waiting for parts.
I will get into the build properly when the Panther is finished.
- Charles A Stewart
- Has liked: 514 times
- Been liked: 933 times
Re: Steve,s Chieftain rebuild
Hi Steve.
Pleased to see you have manage to source the hinges for the storage bins.
Be careful that turret is very heavy, even half loaded. I share this, don't put the turret traverse cog on until you fit the turret. Why, as a novice I have bent the bracket holding the turret motor whilst fitting the turret
There is only going to be a limited amount of bending before something gives. Just a heads up.
Charles
Charles
Hi Charles.
Thanks for the heads up, as it stands just the basic turret casting and a few small details add up to a good work out
Lots more turret parts to do, I will try to keep as many parts as possible as sub assemblies and only bring it all together at the end.
- Been liked: 1842 times
Liking the mods on the turret Steve, you seem to have smoothed out the casting lines on the left side too. Looking good
Your not wrong on the extra detail that can be added to the turret. Especially if you've brought the Armorpax kit, I think the turret becomes a mini scale model all on it's own, a weighty one too!
That's really good advice on turret placement Charles, I take it with the turret turned to the rear deck, access to the traverse pinion is accessible.
Some further Chieftain work carried out
Slow progress at the moment as I have been completing another build for someone ( cannot say at the moment who and what but I guess it will feature in its own thread very soon)
Almost done with the searchlight, just some weld details to add.
The door will be functional via rc along with the light which I will leave as white light.
The searchlight assembly took a lot longer than I expected but it was worth the effort.
Looks great Steve
that''s a really heavy lump even with the big hole down the middle.
Gunners sight made
On to the muzzle reference light source nextRegards
- Has liked: 794 times
Very nice, is it made from "meckle", looks like a lot of pieces.
There's no comparison with the supplied part I have below, which might find its way into the spares bin.
Hi John.
Unfortunately I don’t have the skill or patience to make it out of metal so plastic and had to do, It turned out very sturdy and hopefully should be survive.
I don’t really like using anything but metal but when you think about it many add ons are either resin or 3D printed plastic.
It looks fantastic, very impressive, is it bigger or smaller than the original supplied? I'll be having a go at it in metal so your pictures are most welcome.
Larger all round, not sure what tank Armortek were looking at when they drew up the gunners sight plans.
Next up will be the MRS light housing mounted next to the gunners sight, this item has been completely missed from the kit ( if it has the mirror at the end of the barrel it should have the light projector.)
- Charles A Stewart
Hi All.
Any use Steve? Cheers
Charles
Charles
