Martin's Panzer IV
- Has liked: 790 times
- Been liked: 1891 times
Re: Martin's Panzer IV
Hi Martin
I just wanted to say how impressed I am with your build. Great detail and I really like the brass fittings. I look forward to seeing more of your work.
Gary
Gary
- Martin Hofmann
- Has liked: 151 times
- Been liked: 2014 times
Hi Marco, hi Gary,
thanks for your comments!! Slowly it looks like a Panzer IV. Also done the holders for the springs of the mud guards, mounted the side plates and done the holders for the mud guards on the side. Also the fake cable for the head lamp is on.
Regards Martin
- Martin Hofmann
The next are the covers for the driver and the radio operator. I had built some covers onto the covers with hinges and self made hinges for the big covers, because they are missing. With some brass tubes and a small flat bar it is no big thing to solder them.
Regards Martin
- Martin Hofmann
Now the next is to make the second parts of the hinges and the frame around the covers.
It is very hard to make such small parts consisting of a hole and a counter sunk for M2,5 in sheet of 1mm.
These are the additional holders for the frame.
Regards Martin
- Martin Hofmann
Now i am working on the barrel. The cannon got some set screws for holding the bearing inside - like the real one. The rear part of the gun barrel got a cover made from brass and soldered to the small flat bar around - it's a very tricky job to solder that.
Regards Martin
- Has liked: 749 times
- Been liked: 360 times
Very sweet looking!
And brass, oh what a shiny metal that is!
- Martin Hofmann
Hi Chris, thanks for the nice word.
The next is the turret with the Rommel - Kiste. I use a 2-component aluminium based filler to conceal the milled grooves.
The lid of the Rommel - Kiste got 3 new hinges made by me.
Regards Martin
- Has liked: 1132 times
- Been liked: 990 times
Oops, I've apparently missed several posts here Martin.
Don't really know where to start, but your brass work with the canon cover.
Is delicious.
Have a nice day Martin
Robert
Is delicious.
Robert
- Been liked: 1767 times
- Martin Hofmann
Hi Robert, hi Simon,
thanks for the nice words.
Now the next part is the cupola with all openings for the vision ports with the clear resin inserts.
Regards Martin
- Martin Hofmann
The next are the vision ports and the side doors with all details in it.
Regards Martin
- Martin Hofmann
Thanks Robert,
here are some more brass soldered parts from the Rommel Kiste
Regards Martin
- Has liked: 168 times
- Been liked: 849 times
- Martin Hofmann
Thank you Bob,
Next some more done on the cannon and the turret
Regards Martin
