M26 Pershing 09
Aaron Taylor
Has liked: 28 times
Been liked: 29 times
M26 Pershing 09
Post by Aaron Taylor »
Progress so far and Doc had to try it on for size.
Ray Massa
Has liked: 18 times
Been liked: 116 times
Re: M26 Pershing 09
Post by Ray Massa »
Looking good Aaron. Seems like just a week ago I was at that stage of the build (started my build in March).
I like the white interior - primer or finish coat? I left mine the UPOL etch primer gray.
-Ray
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09
Thank you....It's a primer enamel blend rustolem spray it's pretty durable once cured. The exterior is flat olive drab tamiya and will have a lighter dilute shade to highlight the mechanics the top clear coat will be cerakote clear ceramic. The Tamiya paint is more durable than I gave it credit for and also the color I wanted.... it's hard in this area to find decent spray cans in the amount i needed for some reason.
Ray Massa
Has liked: 18 times
Re: M26 Pershing 09
Post by Ray Massa »
Aaron Taylor wrote:
Mon Sep 11, 2023 8:32 pm
I bought a bunch of bottles of the Tamiya Olive drab but then switched to a Rustoleum Camouflage green spray paint which like the white you used, is a very durable finish. Slightly darker than the Tamiya but I was unsure how the Tamiya would hold up. I ended up using a lot of Tamiya and Vallego paint for the weathering and found that the Tamiya would have been fine, but still happy with what I used. I used many cans of paint for the M26, I think about 8 not including the primer. But I primed and painted all surfaces before assembly, then touched up afterwards.
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09
Yeah I've been doing the same primer on everything if I had the rustileum I would use it next time. But I can't complain tamiya is not the toughest but better than I thought ceracoat on it it will be more than durable. I made the interior white much like the real tank so I could see inside to make any adjustments easier in the field ....I'm on the fence about weathering a model this size one trip on the dry lake bed it's weathered naturally cause it's a real fine dirt (very smooth surface)....which is all we have in the Mojave Desert.
Ray Massa
Has liked: 18 times
Re: M26 Pershing 09
Post by Ray Massa »
Aaron Taylor wrote:
Wed Sep 13, 2023 2:09 pm
I felt the same about weathering. It was hard to dirty up the tank after all that careful painting, but I added some light rusting, and some grime and a little mud splashing. I will post a couple pics in the next day or so.
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09
Yes please send photos of the tank.
Paul Sparkes
Has liked: 94 times
Been liked: 236 times
Re: M26 Pershing 09
Post by Paul Sparkes »
Ray has some amazing pictures on his thread.
viewtopic.php?p=96443#p96443
A very nice paint job.
222 scout car
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09
Ray teach us how you did the letters and the canvas that looks awesome lot of patience there
Ray Massa
Has liked: 18 times
Re: M26 Pershing 09
Post by Ray Massa »
Aaron Taylor wrote:
Sun Sep 17, 2023 11:51 pm
Aaron, I will post a some details on my thread.
-Ray
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09
Please do you did some fine work on that. That's going to be fun to patrol the back yard battlefield
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09 weathering powders
So found this waterproof interior exterior clear spray I use the Tamiya weathering pigments and this won't make the powders run it seals and waterproofs them and you can dullcoat over the top without the white chalky finish it makes on the pigments. Heads up both spray coatings are really smelly.
Aaron Taylor
Has liked: 28 times
Re: M26 Pershing 09 did some measurements today
Got some Photos and measurements today at fort irwin with permission from the museum no embossed rear fenders I noticed this may have been a rebuild it initially came from Europe.
