Mr Dawe's Centurion.
Damon Resch
Has liked: 915 times
Been liked: 82 times
Re: Mr Dawe's Centurion.
Post by Damon Resch »
A true modeling tour-de-force, such a pleasure to get these detailed updates almost daily. Thanks for sharing as always!
Has liked: 2282 times
Been liked: 7196 times
My pleasure Damon.
Not to much to show for an afternoons work today but editing in cura, printing and making tiny parts fit correctly take time.
Inlet manifold water pipe connections
These intakes have proved problematic but I think I'm there now but for maybe a slight reduction in height once I'm sure of the air cleaner pipe work heights
Printing and turning small parts, and I will be for sometime
I may have to lower the air intakes but not sure yet as I have no dimensions to cross reference, it's all guess work and if it looks right then maybe it is right
Once the engine bay cassette is in place everything above the rockers must be demountable, I have to build it all on the bench, dismantle and reassemble, once the engine is slotted in for the last time it can all be bolted in place.
The last of this week's exciting episodes
Difficult to see but I have added the fuel pipe which connects the carbs
And another layer to mill
The carburetors do show
Maybe a long winded way to make up the manifold but it works in my mind
It's starting to get some depth now
I shall mill the cooling ribs from a separate piece of material
Getting on.
The last layer for now
You can see all the layers I've used
The oil can decals arrived
Lots of hand filing
Lots of hand filing
Great tool this guillotine
I now need to fit more cooling water fittings, I actually need four of these so I will have to print some more
I decided not to mill the fins
Coming on
Coming on
This material sure does mess up the machines
Now can I get a portion of those fans to fit?
Lots of important little jobs done and underway
Nice photo of a mid range meteor
Editing the elbow file until it will fit this will link the top hose to the radiator
Water pipe union being printed
I'm hoping I can get the generator running and turning the fan pullies but not sure there's enough room just yet
All the ribs are now done and the inlet manifold water pipes are now in place, although they look fixed there not, and it can all be lifted out
A quick set out using similar size items to give me an idea of what goes where
Something to keep me awake at night
Not very exciting I'm afraid but all very necessary.
Milling required to get that look I want
Rear engine water pipe assembly now made and installed, again all these pipe fittings need to be removable
Very thin ali sheet can be cut with a craft knife, great for fuel pipe " p" clips
Very small casting/parts numbers added, I don't think that you can get any smaller than these
The tiny casting letters are a bugger being this small but they add to the overall effect
Always pin drilling
Always pin drilling
Fuel pipes and "p" clips
I'm nearly done with this manifold
Editing in cura and printing the air cleaner drums and drum tops today.
A tip for those like me that are not familiar with creating stl files from engineers drawings, collect basic stl files from the various sites on the internet which are often free, simple objects like cylinders, discs, square boxes, rods and anything that looks interesting, then using your imagination and Cura edit those objects , you will need to join pieces together to make more complex parts like engine blocks and pipe fittings ect.
Cyno offers a very strong adhesive for pla, once bonded you will have difficulty separating those parts. Drilling and tapping works well to.
The base of that right angled water fitting that I made yesterday is actually the thermostat housing. That's what the bypass pipe is for.
Anyone know what the air cleaner plate says?
This file started life as the main body for a 1/4 scale oil drum. It will now be the sliced body for our Centurion air cleaner
Phil Dawe
Has liked: 757 times
Been liked: 300 times
Post by Phil Dawe »
Phil, I am sure your followers on the Centurion Appreciation Society Facebook site will answer your question regarding the brass plate :D
Good point well made Phil, when I have a good collection of progress photos I shall ask . 8)
The air filters are coming along
Some may remember my Chieftain's engine bay
The air filter bins all printed and the tops cleaned up and bonded in place
I think I will cut these on the mill
Leaving the joints loose helps get the perfect fit, once in place and I'm happy cyno can be applied
The tiny thumb screws x 12 needed
Milliput required to replicate the cast ali joint fillet
While this lot cures I shall be turning the thumb screws in steel and brass
Ugly things right now, milliput will give us the look we are after
Maybe a little surface texture here and there, the rubber pipe links, pipe clips, fixing down brackets and the air filters will be done
12 required
12 required
It's a lot of fiddly work x 12
Handles
Handles
Rivited instruction notice but no words.....yet
Grey primer
Grey primer
Aluminum paint
Aluminum paint
I quite like the cast ali texture
Phil Dawe
Post by Phil Dawe »
Air Cleaner porn! Love it......! 8)
Moving on to the nr side fuel tank and that dinky engine for a bit.
More printed parts
More printed parts
Not very exciting but all necessary work
I actually hold the bigger pieces with carefully placed fingers
Bottom and sides of our sliced down fuel tank bonded nice and square
One stage at a time or it will ping appart
I need to make the block taller
A little gentle heat will help relax and shape the outer fuel tank skin
Lots of off cuts used to make up the head
Now I just need to be patient and let it cure for a bit so I will carry on with the gue
That's more like the profile
Setting out the spark plug positions
I need to let one corner of the fuel tank in so that it misses the exhaust tee piece
There's a lot of tiny parts involved in this gue
Your daily update , I would normally spend around just 3 hrs a day in the workshop , sometimes am sometimes pm what ever my spine will allow but today was a full day.
Just as well use the mill
Setting out the fittings
The exhaust cut out done
Fluffy stuff under the fuel tank restraining strap, I suppose this stopped any chaffing?
I'm not happy with the scaled depth so I'm going to remove 10 mm from the rear
I printed this at lunch time
Fuel pipe and fuel level sender next
Those are expensive rivets
All done for now, this fuel tank would have been twice as long and twice as deep as this slice but we just don't have the room.
Checking for ceiling height
It's starting to fill up in there
Been 3d printing parts for the Morris side valve gue engine today
Did try printing the spark plugs but no luck
Dynamo and distributor
The distributor will need changing from vertical outlets to the horizontal exits
Oil filter can
Oil filter can
Dynamo/generator, started motor and remote oil filter top fittings
The long oil filter
The long oil filter
12 v ignition coil
12 v ignition coil
