Mr Dawe's Centurion.
- Has liked: 913 times
- Been liked: 82 times
Re: Mr Dawe's Centurion.
A true modeling tour-de-force, such a pleasure to get these detailed updates almost daily. Thanks for sharing as always!
My pleasure Damon.
Not to much to show for an afternoons work today but editing in cura, printing and making tiny parts fit correctly take time.
The last of this week's exciting episodes
Getting on.
Lots of important little jobs done and underway
- Nice photo of a mid range meteor
- Meteor-engine.jpg (130.95 KiB) Viewed 4516 times
Not very exciting I'm afraid but all very necessary.
Editing in cura and printing the air cleaner drums and drum tops today.
A tip for those like me that are not familiar with creating stl files from engineers drawings, collect basic stl files from the various sites on the internet which are often free, simple objects like cylinders, discs, square boxes, rods and anything that looks interesting, then using your imagination and Cura edit those objects , you will need to join pieces together to make more complex parts like engine blocks and pipe fittings ect.
Cyno offers a very strong adhesive for pla, once bonded you will have difficulty separating those parts. Drilling and tapping works well to.
- The base of that right angled water fitting that I made yesterday is actually the thermostat housing. That's what the bypass pipe is for.
- Meteor-engine.jpg (130.95 KiB) Viewed 4389 times
Phil, I am sure your followers on the Centurion Appreciation Society Facebook site will answer your question regarding the brass plate
Good point well made Phil, when I have a good collection of progress photos I shall ask .
The air filters are coming along
- Some may remember my Chieftain's engine bay
- IMG_20200715_112925_kindlephoto-4888207.jpg (151.2 KiB) Viewed 4243 times
Maybe a little surface texture here and there, the rubber pipe links, pipe clips, fixing down brackets and the air filters will be done
Moving on to the nr side fuel tank and that dinky engine for a bit.
Your daily update , I would normally spend around just 3 hrs a day in the workshop , sometimes am sometimes pm what ever my spine will allow but today was a full day.
- 15281224490_28a8b129c1.jpg (67.71 KiB) Viewed 4008 times
Been 3d printing parts for the Morris side valve gue engine today
- 2.png (48.24 KiB) Viewed 3894 times
