Tom's Pershing Build
Tom Miller
Been liked: 346 times
Re: Tom's Pershing Build
Post by Tom Miller »
I went to the hobby shop to get some music wire and found they now sell carbon fiber rods. I bought some .078 dia.
Ronald Goodall
Has liked: 4 times
Post by Ronald Goodall »
G'day Tom, I was hoping you could help me with a situation I have encountered.I tried to fit the drive motors but could not get them in because they were hitting the back panel so I removed the bolts from the bottom of the rear panel moved it out of the way and the motors went in OK,however I can only get one bolt in (the middle one) Did you encounter the same problem if so how did you get the other two bolts in under the motors? Any advice would be greatly appreciated. Cheers
Ron Goodall
Tom Miller
Hi Ron,
Yes you must remove the rear panel to install the motors. I had no problem installing the motor bolts. I am not sure what you mear by the middle bolt. The bolts are spaced rather equally around the motor and are not hard to get at. Are you sure you have the motors installed correctly?
Tom
Tom Miller
Hi Ron,
Now I get it. You are taking about the 3 bolts that hold the rear panel on not the motors. Yes I remember the outer two bolts being a problem. I just don't remember how I solved the problem. I may have used hex bolts if that made wrench accress easier. Or I just left them out. I just don't remember. Sorry.
Tom
Brian Womersley
Has liked: 33 times
Been liked: 28 times
Post by Brian Womersley »
Can I come in there…. It is just possible… just remove the top two bolts completely and only loosen the bottom three just enough to tilt the back plate outwards enough to allow the motors to clear…. Fit motors with their spacer discs and then use a small angled Allen key to take small bites at the two bolts under the motors… you will feel the back plate pulling in and tightening up… then fully tighten the middle and top two bolts… It ain’t going to fall off 🙏
Brian
Nick Chiocchio
Has liked: 46 times
Been liked: 39 times
Post by Nick Chiocchio »
Hi Tom,
For the markings, did you use stencils or maybe decals? Just curious, I have a Cricut I used for serial numbers and other markings on my other 1/6 scale vehicles and it worked well. I was wondering how you did yours? I have a while before I need to deal with my tank's markings.
Nick C.
Tom Miller
I used stenciles. I bought them from https://www.noostadirect.com/
