Late cupola cover / umbrella
- Has liked: 794 times
Yesterday I thought of something that I can add to my late Tiger 1. It is the cupola cover or umbrella.
I have been searching for a photo of this item to see if it's difficult to fabricate but no luck yet. I also have the impression that somebody posted a photo here recently but also no luck in finding it here.
Can somebody kindly tell me where to find these photos?
- Has liked: 1043 times
- Been liked: 100 times
Re: Late cupola cover / umbrella
Something like this?
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Bailey Bridge + Extension
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
- Marco Peter
- Has liked: 1539 times
- Been liked: 798 times
I need to lookup my pictures for Ed too so when I have time...
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Thanks Riny for that photo. Is that your handiwork?
Thanks Marco. I guess that is where I saw it recently. Totally forgot about it.
Not my work, its from Michael's fantastic Tiger 332.
I do not have the skills to do this
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Another question.
Is the material for the cover sheet metal or canvas?
Thanks again.
Thanks again.
- Ed Groenenberg
- Has liked: 96 times
- Been liked: 639 times
On the Tiger at Militracks it was cloth / canvas.Vince Cutajar wrote: ↑Tue Jun 13, 2023 1:50 pmAnother question.
Thanks again.
Thanks Ed for the info.
Made a rough 3D model to see what will be involved in fabricating the frame (green colour)
Frame to be made with 2mm diameter round stock. I still have to see if I have enough material for it. Trying to avoid having to buy the stock online as it has become really expensive to import things.
- Ed Groenenberg
Hello Vince.Vince Cutajar wrote: ↑Tue Jun 13, 2023 4:33 pmThanks Ed for the info.
That's a bit of a coincidence....
On my 2004 tiger, the cupola (the drum type) had 2 small studs/tubes on it,
Only these were more or less in front and the back of the commander.
I solved it by drilling 3 new holes in the top part of the cupola (it consists of a rop and a bottom ring),
and twisted it so these 2 mounts are now left and right of the commander.
The hatch is now at the back and also acts as a sort of shield?
I'm using 3mm brass rods for the 2 upward sections (needed to shave off about 0.4mm)
and 2mm brass rods for the rest of the frame.
Regards,
Ed
- Marco Peter
- Has liked: 1495 times
- Been liked: 1699 times
Interesting thread. Was this a Tunisian addition ?
Marco, those stills from your video are awesome. Seeing those photos made me change the way I should go about attempting to do it.
Fingers crossed.
Fingers crossed.
Adrian, according to the following, they were introduced in November 1942.
https://tiger1.info/EN/Umbrella.html
I believe that the umbrella mounting posts remained till the end of production. I believe I once saw a photo of a King Tiger with that umbrella also.
- Marco Peter
THANKS! Thats why I do it!Vince Cutajar wrote: ↑Wed Jun 14, 2023 3:04 pmMarco, those stills from your video are awesome. Seeing those photos made me change the way I should go about attempting to do it.
Many thanks Vince.
