KT 2019 #29
- Has liked: 1485 times
- Been liked: 1695 times
Re: KT 2019 #29
My apologies, I thought they were the other way round, but having checked, I see you are right:
"Loctite threadlockers are primarily designed to prevent fasteners from leaking or loosening from vibration. The difference between red and blue threadlocker is a matter of strength and removability. Loctite threadlocker blue is designed to easily be replaceable with common tools, whereas red is a more permanent fix. If you have trouble keeping it straight, here’s a helpful rhyme to jog your memory: “Blue, easy to make new. Red, full strength ahead!”
I use 222 for low strength bonds and 243 for medium strength bonds.
222 is actually purple - which I was remembering as red - and 243 is blue. The only high strength stuff I have here is 270, which is green.
- Has liked: 1039 times
- Been liked: 79 times
- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
Re: KT 2019 #29
That will be the permanent solution.Michael Allen wrote: ↑Sat Feb 25, 2023 2:56 pmMany thanks
I’m using 638 which is also green for the wheels which I assume is ok?
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1117 times
Re: KT 2019 #29
Over the years I've found that if one runs one of these things enough nothing is permanent. Doesn't seem to matter large or small scale - if some bit can come loose it's almost certain that it eventually it will. Applying the appropriate laws of inconvenience it will happen at the worst time. I've just accepted that it will and try to do maintenance checks. I never assume any model is 'run and forget''. Years of running gas powered models taught me the hard way - never let maintenance slip.
But we all love our hobby right?
- Has liked: 8 times
- Been liked: 29 times
Re: KT 2019 #29
Hello Michael,
The King Tiger would have been left in Red Oxide Primer for the Lower Hull interior and Torsion Bars were generally black. Where the fighting compartment and turret is the colour was Elfenbein RAL 1001 which is an Ivory Colour. This information is from Wehmacht Heer Camouflage Colours 1935 to 1945 by Tomas Chory.
Kind regards,
Will.
Kind regards,
Will.
Re: KT 2019 #29
Can I ask that KT builders give me some advice please.
Can you let me know what fixings you used for parts numbered CK0602 and CK0601 on page no.31A
- Charles A Stewart
- Has liked: 511 times
- Been liked: 933 times
Re: KT 2019 #29
Hi Mike
Looking at the manual(31a).
May I suggest M3x25 cap as nuts are m3 as used on ck0604?
Cheers Charles
Cheers Charles
Re: KT 2019 #29
[attachment=
Very slow progress to KT 29 but I’m very pleased with how it is coming together
- 43B393A6-56D0-4271-9ED4-877151610681.jpeg (20.69 KiB) Viewed 3995 times
- F0BD0CE0-3776-47E7-8683-C7C4871201BD.jpeg (52.94 KiB) Viewed 3995 times
Re: KT 2019 #29
Many thanks
- Brian Ostlind
Re: KT 2019 #29
Looks like an old sixth scale icons piece from Mike stannnard. I may have the instruction sheet that came with mine. I’ll take a look.
- Brian Ostlind
Re: KT 2019 #29
Just shows just how much you know your subject Brian. It’s definitely the right Jack. Have you fitted one to one of your tanks?
