Hetzer sprockets -Toast!
DaveMacri
Has liked: 13 times
Been liked: 118 times
Post by DaveMacri »
Well it finally happened, I was observing these sprocket teeth wearing down over the past 6 months driving in the sand and dirt here-today they fianally gave up the ghost! Need to replace with steel sprockets as the aluminum is a tad to thin, any ideas for source?
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Re: Hetzer sprockets -Toast!
Post by Brian Ostlind »
Yeah, but it will cost you…
Gerhard Michel
Has liked: 3 times
Been liked: 691 times
Post by Gerhard Michel »
I would prefer aluminium, nevertheless. It's better to loose cheap sprocket rings than a complete set of track links. These rings you can order at a water jet cutting manufacturer according to your demand and complete it with drilled holes and so on. I made this at my King Tiger and my Hunting Tiger.
Here 2 types of water jet cutted rings at reworking on lathe:
And here a completed water jet cutted sprocket ring mounted (all parts used on non-Armortek models):
Gerhard
DaveMacri
Has liked: 13 times
Post by DaveMacri »
hmmm
DaveMacri
Has liked: 13 times
Post by DaveMacri »
Better pics of deterioration level of the teeth with just about 2 hours total of run time in prairie grass and sandy surface.
Jerry Carducci
Has liked: 3 times
Been liked: 1120 times
Post by Jerry Carducci »
I've used a laser /water jet machining outfit here, actually down in sili valley. They're quick, reasonable and J Littlefield used the same outfit
to cut sprocket rings for his 1:1 scale models..
PM if you want their info. They do prefer working off of at least a good drawing with dimensions with a CAD file being a best bet.
DaveMacri
Has liked: 13 times
Post by DaveMacri »
Thanx for the intel, Liam Mahoney is planning on doing steel sprockets and tracks for his Hetzer after looking at his kit since this occurrence. I will be getting a set from him...
Roy Maynard
Been liked: 2 times
Post by Roy Maynard »
I’m currently building a Hetzer and would be interested in purchasing the steel replacements. Is there contact information available?
Roy
Minnesota USA
Chang
Has liked: 16586 times
Been liked: 487 times
Post by Chang »
Roy Maynard wrote:
Sun Apr 09, 2023 1:58 pm
Roy
Minnesota USA
Hi Roy,
Liam Mahoney's email : liam@lsm.net.au
Good luck.
DaveMacri
Has liked: 13 times
Post by DaveMacri »
Update on the steel sprocket rings, received replacements from Liam Mahoney and tested them out on the tank, they run perfectly now with no signs of wear on either the track links or the sprocket teeth. I have about an hour in on the test time in sand terrain...
Brian Ostlind
Woohoo I need some too!
Kees van Rijswijk
Has liked: 353 times
Been liked: 161 times
Post by Kees van Rijswijk »
Hi,
count me in for a set.
kind regards Kees
Roy Maynard
Been liked: 2 times
Are steel sprockets still available from Liam?
Please email me at roydefiant@aol.com
Roy Maynard
Liam Mahoney
Been liked: 315 times
Post by Liam Mahoney »
Hi Roy
Yes still available, email sent.
Thanks Liam
