Hetzer sprockets -Toast!
- Has liked: 13 times
- Been liked: 118 times
Well it finally happened, I was observing these sprocket teeth wearing down over the past 6 months driving in the sand and dirt here-today they fianally gave up the ghost! Need to replace with steel sprockets as the aluminum is a tad to thin, any ideas for source?
- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
- Gerhard Michel
- Has liked: 3 times
- Been liked: 687 times
Re: Hetzer sprockets -Toast!
I would prefer aluminium, nevertheless. It's better to loose cheap sprocket rings than a complete set of track links. These rings you can order at a water jet cutting manufacturer according to your demand and complete it with drilled holes and so on. I made this at my King Tiger and my Hunting Tiger.
Here 2 types of water jet cutted rings at reworking on lathe:
And here a completed water jet cutted sprocket ring mounted (all parts used on non-Armortek models):
Gerhard
Gerhard
hmmm
Better pics of deterioration level of the teeth with just about 2 hours total of run time in prairie grass and sandy surface.
- Jerry Carducci
- Been liked: 1116 times
I've used a laser /water jet machining outfit here, actually down in sili valley. They're quick, reasonable and J Littlefield used the same outfit
to cut sprocket rings for his 1:1 scale models..
PM if you want their info. They do prefer working off of at least a good drawing with dimensions with a CAD file being a best bet.
Thanx for the intel, Liam Mahoney is planning on doing steel sprockets and tracks for his Hetzer after looking at his kit since this occurrence. I will be getting a set from him...
- Been liked: 2 times
I’m currently building a Hetzer and would be interested in purchasing the steel replacements. Is there contact information available?
Roy
Minnesota USA
Roy
Minnesota USA
- Chang
- Has liked: 16564 times
- Been liked: 487 times
Hi Roy,Roy Maynard wrote: ↑Sun Apr 09, 2023 1:58 pmI’m currently building a Hetzer and would be interested in purchasing the steel replacements. Is there contact information available?
Roy
Minnesota USA
Liam Mahoney's email : liam@lsm.net.au
Good luck.
Update on the steel sprocket rings, received replacements from Liam Mahoney and tested them out on the tank, they run perfectly now with no signs of wear on either the track links or the sprocket teeth. I have about an hour in on the test time in sand terrain...
- Brian Ostlind
- Kees van Rijswijk
- Has liked: 353 times
- Been liked: 161 times
- Been liked: 315 times
