My Mid Production Tiger
your not allowed on here mark,you only own the company.iv,e got one smooth and one rough,tanks that is,i knew one would be right,this thread could cause much head scratching.
simon manning
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
WHAT! Now I have to sand all my texturing OFF!? sarcasm
Mike, I will be addressing the symmetrical pattern grills at a later date. I like Steve's "replacement part" solution too.
regards
Has liked: 1038 times
Mark has a point. The Bovington Panzer III shows a good example of German rolled armour plate. The vehicle has spent most of its life since the war in a hangar. The surfaces are remarkably smooth, the main surface markings being striations from the rolling process.
Regards. Stephen
Kent Wiik
Post by Kent Wiik »
I do not know but the surface seen in Stephens photos are exactly the surface I am aiming at when I try to get the rolled steel look.
Look closely and one sees it is far from perfectly smooth or do I need new glasses...?
The cast surface seen at cupolas, MG ball mount and grate are (was) far rougher.
All this can be read about in various "how to do magazine" for the 1:35 builders but I think I was the first one to add it on a metal 1:6th tank with my Hetzer.
So blame me :oops: :wink:
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Howdy,
I am no expert, but I work on cargo ships, both new and old, and we also carry modern armored vehicles occasionally. It seems to me that while exposed rolled steel is definately "textured" by the elements, the new rolled steel and the AFVs we carry do have a texture which may not be measurable but is discernable to the eye in the reflectivity of the surface. (not sure the term reflectivity is correct).
Though not yet experienced with the 1/6 Tank yet, this feel to the surface was always the toughest effect to recreate in the 1/35 scale models. (I stippled the surface with a base of thick paint).
On the modern AFVs you could feel this waviness with your hand too.
Thanks for the time, just a thought.
-Brian
