Early Panther G #2 build
- Has liked: 912 times
- Been liked: 82 times
Re: Early Panther G #2 build
Dave, beautiful work and zimmerit application. I’m guessing that the bare aluminum was primed before zimmerit, then the zimmerit was laid down then the initial coating of Dunkelgelb?
- Has liked: 13 times
- Been liked: 118 times
Correct,I prime everything loose or assembled-then zim and more primer to seal that with the base color Dunkelgelb next. Then I brush on to assure it got in all the crevices.Damon Resch wrote: ↑Wed Dec 28, 2022 11:26 amDave, beautiful work and zimmerit application. I’m guessing that the bare aluminum was primed before zimmerit, then the zimmerit was laid down then the initial coating of Dunkelgelb?
Once I get the camo on it I will be able to find it!
Took three attempts to get the pattern I like, waiting on a few more items from UK then I can weather it up and move off the bench.
- Been liked: 1768 times
Excellent finish, a lot of work to achieve to this stage, well done, regards simon manning.
- Has liked: 252 times
- Been liked: 442 times
Hi Dave
That paint scheme looks superb, like the double road wheels on the turret I am going to do the same and also have track links on both sides of the turret.
Will post a video of it running when finished?
Gary
Completed of latest release Panther G from Armortek.
