Early Panther G #2 build
- Has liked: 13 times
- Been liked: 114 times
- Has liked: 220 times
- Been liked: 93 times
Re: Early Panther G #2 build
Great looking Panther G! 2022 #2 Panther G? also highly detailed and accurate zimmerit coating work
Best,
Jae-seung
Best,
Jae-seung
- Has liked: 1211 times
- Been liked: 1386 times
Don't lose it if you take it outside...
- Has liked: 229 times
- Been liked: 213 times
Thats look brilliant, please more pics!
Alex
Alex
Armortek Hetzer no 31 (2022).
Quicquid agas age
- Has liked: 252 times
- Been liked: 442 times
Superb build, looks fantastic quality zimmerit.
Hat's off how you done you build so quickly is massively impressive.
- Has liked: 104 times
- Been liked: 701 times
- Brian Ostlind
- Has liked: 959 times
- Been liked: 2041 times
Yes his is a ‘22Jae-seung Roe wrote: ↑Mon Dec 26, 2022 4:31 pmGreat looking Panther G! 2022 #2 Panther G? also highly detailed and accurate zimmerit coating work
Best,
Jae-seung
yes this is the current release Panther, installing the option packs and battery now so I can close up the top deck and roof on turret-apply welds and camo ..Jae-seung Roe wrote: ↑Mon Dec 26, 2022 4:31 pmGreat looking Panther G! 2022 #2 Panther G? also highly detailed and accurate zimmerit coating work
Best,
Jae-seung
I will post more pics when I get the deck welds on.
- Has liked: 281 times
- Been liked: 642 times
What a lovely job and the Zimmerit is superb.
What have you used and what is your method?
2022 Panther G #15
This was my first attempt at Zim, I used wall tile grout mixed with a dilution of wood glue and water. Mix a bit firmer than tooth paste consistency and then applied with a drywall knife/putty knife. Used the set of zim tools from 6th Scale Icons FOA(which is not recommended anymore) to shape the rows in a vertical pattern. Small dowel rod with a dull point was used to then cut the horizontal and vertical rows. Don't extend yourself with area coverage as the material starts to cure in about 45 minutes. Once it has firmed to dry appearance knock down the rough rows and high points with sanding block.Malcolm.Plumb wrote: ↑Tue Dec 27, 2022 8:24 amWhat a lovely job and the Zimmerit is superb.
What you have used and what is your method?
Great, Thanks.
Just for a matter of interest which of the two available size 6th Scale Icons Zimmerit tools did you use?
Any idea why they are not recommended?
2022 Panther G #15
The tools are fine but FOA are no longer recommended as a supplier as they accept orders but never deliver, meaning people have to resort to CC companies, Paypal or the courts to get their money back.
Thanks Adrian, nice to know.
I have requested a set from Armortek as mentioned in their custom Panther G build thread.
I think I'll just send them an email to see what the state of play is with them.
2022 Panther G #15
Don't forget Armortek are closed for Christmas, back on the 3rd January.
