Series 1 4x4 car - Spring 2023
- Been liked: 3665 times
We are very pleased to announce that our next model kit will be a 1950 Series 1 4x4 car.
The Armortek Series 1 will have a CNC machined aluminium chassis and steel body. It will feature leaf spring suspension and have dual differentials for 4 wheel drive. The kit will be remote control capable through the option of a motion pack.
The Armortek Series 1 will be available in Spring 2023 and will cost £1,650 plus VAT and shipping. The order book will open in January 2023 for this LIMITED EDITION kit.
Dimensions of the Series 1 are:
Length: 56cm (22")
Width: 26cm (10")
Height:32cm (13")
More details will be available as the design is finalised.
Length: 56cm (22")
Width: 26cm (10")
Height:32cm (13")
- Has liked: 8 times
- Been liked: 701 times
Re: Series 1 4x4 car - Spring 2023
Hi Armortek
Interesting choice for the next model and as always I hope it is a success for you.
After the last survey you identified 6 possible kit releases and I was wondering if one or more of these are still in your plans ?
- Has liked: 260 times
- Been liked: 190 times
A good one, I hope a wider community of interests discovers this model. Now my Gypsy Uncle had one or two of these in his youth!
- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
- Has liked: 297 times
- Been liked: 645 times
- Tim Page
- Has liked: 40 times
- Been liked: 471 times
One very interesting option...
CheersTim
- Has liked: 2278 times
- Been liked: 7191 times
Excellent choice of vehicle.
- Tim Page
That looks really good.
Any idea of estimated weight for the landy?
- Been liked: 35 times
Awesome idea but Armortek has it backwards, now the body is going to rust away and the frame is going to stay solid?
- Charles A Stewart
- Has liked: 506 times
- Been liked: 916 times
wondered when someone would spot that one
( other similar high-street models are available)
three days , not bad.
Cheers Charles
Cheers Charles
Not yet. We will jiggle the mix of aluminium and steel that we use in the chassis to try to get an even weight distribution over the axels
If we made the body Aluminium, it would need to be at least 3mm thick. Otherwise first time you pick it up it would buckle.johnny johnson wrote: ↑Thu Dec 08, 2022 10:45 pmAwesome idea but Armortek has it backwards, now the body is going to rust away and the frame is going to stay solid?
I love Armortek models, my comment was a direct result of owning a 1984 LR90, (defender here) body was awesome, everything else had major rust in it, would never complain about your models, how they are built or which ones are built, only happiness and appreciation here.
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1106 times
Oooooo! I actually like that option Tim, the imagination can run wild with that...
