David's carrier build.
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Re: David's carrier build.
Hi Phil,
Sorry, designed the decals for our one. I'll send you a couple of the printed, self adhesive ones. You'll still need to cut them but once stuck and sealed with varnish should be fine.
Dave
www.armorpax.net
Hi Phil,
Have you used the 2nd set of decals yet? If not send them back and I'll credit David.
Dave
www.armorpax.net
Has liked: 2282 times
Been liked: 7196 times
Dave I have mounted the decals onto a piece of .5 plasticard and the technique is working well, it supports the fragile decals and provides a nice flat stable surface so I'm happy, you just need a steady hand with a scalpel.
Graham P Hough
Has liked: 26 times
Been liked: 193 times
Post by Graham P Hough »
What a good idea. I will borrow that if I may.
Hi Phil,
Good idea, there are a printed set inbound too but with the postal strikes not sure when they may arrive.
Dave
www.armorpax.net
Lots done, forgot to mention ref the decals, you will need to use clear lacquer to seal the decal sheet once it's transferred to the plasticard .
Fiddly and time consuming job but worth the effort, you will need to remove lots of little screw and switch details to give you some room to apply the decals
That's better
That's better
The radio bolted in but easily removable
Hand rails
Hand rails
These need fixing with Velcro
Dave do you want the front sand guards fitted?
The rounded hull side tops now fitted
Dave Green
Has liked: 88 times
Been liked: 62 times
Post by Dave Green »
Looking good Phil. Yes please on the sand guards.
A bit more done
Final track link journal dressing maybe for the last time
A little tip, a small amount of cyno to hold the difficult to get to m2 bolts in place
A tad of belly weathering whilst she's on her side
Sand guards mounted
Sand guards mounted
Using uv cured resin to make the instrument glass, a tip, be patient and let the resin flow out then apply the uv lamp to cure the resin, to much light and you will get bubbles!
Just a couple of hours today prepping and painting the myriad of small parts associated with the front plate .
If you can get over the track fetling with this model then you will love it, there so much in such a small kit.
Everything goes through the brass brush treatment
Not a great deal of cleaning up to do but each piece needs a little attention
The sun was out so paint curing is so much quicker
A good afternoon working on the uc
Meters of this required
An awkward piece to hold
Lots of material to remove
These areas need removing
Lots of this required
Plasticard stiffners added to the rope stowage
If anyone has any photos of the bren gun hatch and area I would be very grateful
Dave Green
Has liked: 88 times
How about these
Thanks boss they are great.
Dave Green
Has liked: 88 times
Another flap open and bren ready for action
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Whats with the nuts and bolts why no rivets.
Dennis.
You are a legend Dennis.
