Panther G (July 1944 version)
Charles A Stewart
Has liked: 513 times
Been liked: 933 times
Re: Panther G (July 1944 version)
Post by Charles A Stewart »
Hi Folks.
This is looking a cracking build, I am looking forward to mine arriving.
What's the chances of an options pack, to upgrade to a late Panther G; i.e. chin gun mantle and the crew heater fittings which would give an option for changes?
Of course there are other variations, Just a thought.
Evening all.
Charles
Been liked: 3704 times
Charles A Stewart wrote:
Sun Aug 21, 2022 9:36 pm
Charles
Any variations that we make need to be planned in quite early on - especially as we commit to production numbers and get the materials ordered in quite early on.
In addition, making 1 or 2 of a part is not financially viable, it really needs to be in the double digits - otherwise all the design, set up, tooling, prototyping etc costs need to be recovered over the 1 or 2 parts.
Having said all that - we do actually still have stock of the cast larger fan cases. Maybe we will put a couple in the shop for the Open Day.
Panther G hull periscopes - made of perspex.
Just waiting for the periscope armour to be bent up now.
Didier Molard
Has liked: 61 times
Been liked: 99 times
Post by Didier Molard »
great additon the perspex periscope, a bit of paint will make it realistic
did you updated the bracket for the rear hatch to have a vertical axis rather than parallelto the rear wall?
Rear deck on the Panther G - now complete with all the details.
Front mudguards on the Panther G - also now complete.
Alex Easten
Has liked: 244 times
Been liked: 217 times
Post by Alex Easten »
More pics pleaaaassse :)
Quicquid agas age
This week we have started the massive job of packing up the Panther G parts.
And when we say massive, we really do mean MASSIVE. We need to pack up .....
- Over 6 tons of metal
- Over 13,000 parts need to be bagged or wrapped in either foam or anti rust paper
- Almost 100,000 fasteners need to be counted out and bagged
Packing is progressing smoothly so far ... but there is still a way to go.
By Tuesday 4th October we should be able to give a better indication of the likely shipping date for the kits. Not long to wait now!
Front decks being wrapped in foam
Still lots to wrap/ bag
Dale jordan
Been liked: 525 times
Post by Dale jordan »
Big Job well done so far . It takes a while to unpack one kit ! How many Panther in this batch ? do you have help ? if so how many persons
cheers Dale
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Post by Brian Ostlind »
Looks like 80 packages.
Jae-seung Roe
Has liked: 315 times
Been liked: 134 times
Post by Jae-seung Roe »
Great to see the packing has started! I was wondering if the fully assemeblemd Panther G 2022 final model images with running movie clip like Churchill's one will be followed sooner or later! :D thank you!
Brian Ostlind
Hello, I thought of a question since this is a specific date tank do we also know what factory or manufacturer it would be modeled after?
Any shipping updates?
Thank you!
mark lawson
Has liked: 2519 times
Been liked: 445 times
Post by mark lawson »
Morning Brian, I think the kit is more of a generic kit based on the early Ausf G models. Manufacturers of the Ausf G are
M.A.N
March 44 - 2. Fgst. Nr 120302
April 44 - 105. Fgst. Nr 120407
Through to April 1945
Daimler Benz
May 44 - 78. Fgst. Nr 124378
June 44 - 120. Fgst. Nr 124498
M.N.H
July 44 - 108. Fgst. Nr 128408
August 44 - 131. Fgst. Nr 128539
Information comes from page 89 "Germanys Panther Tank the quest for combat supremacy"
Depending on which theatre you want to base your build on could help narrow down the manufacturer of the Panther you would like to build, if you wanted to base your build on Normandy there are some divisions which were never issued the Ausf G one of them being 2.Panzer Division who were mainly equipped with Ausf A with up to 4 Ausf D, they never received any Ausg G until after they were withdrawn back to Germany. The majority of Ausf G that served in Normandy would have been from the M.A.N factory with a small number from Daimler Benz, I have yet to see a confirmed picture of an M.N.H built Ausf G in the Normandy theatre.
Using this list to help identify allocation numbers it may be possible to identify a particular division a Panther was allocated to, however the list does not show which Ausf was issued to a given division;
https://www.panther1944.de/index.php/en ... liste-1944
After this we then need to rely on pictures.
some unit histories using Panzer regiment numbers as opposed to the division number which can vary.
https://www.panther1944.de/index.php/en ... -histories
book's to help with detail are;
Panzer Tracts No.5-3
Achtung Panzer - No.: 4 old but still very relevant.
Tankograd In-Detail Panther G - Jagdpanther
Panther and it's variants Walter J. Spielberger
PANTHER EXTERNAL APPEARANCE & DESIGN CHANGES exceptional book
Nürnberg’s Panzer Factory a photographic study
Panther in detail Ryton Publications
Try and steer clear of Waldemar Trojca his books are full of errors.
This is a page of Panther related books covering all variants.
https://www.panzerwrecks.com/product-ta ... nk/page/2/
RAG Militärmodellbau
IG Militärmodellbau
First run for the Panther G from a couple of weeks ago. Bedding in the running gear.
Packing is furiously under way!
The panther kit will consist of 4 boxes in total.
We have started on Box 4 ... a big stack of them are ready.
Panther G Box 4.jpg (87.96 KiB) Viewed 2702 times
