Another Tiger
- Brian Ostlind
- Has liked: 976 times
- Been liked: 2068 times
Re: Another Tiger
All major sub assemblies are complete, I am ready to start adding Zimmerit. Will get the materials and get started plus make how to Zimmerit video.
- Brian Ostlind
Update before Zimmerit
No Zim yet, was waiting for Marks jack so I could mount it before I get started, so I made a video reviewing the upgrades that I have planned.
- Brian Ostlind
Mounting the rear jack
I’m back and hoping to steadily keep working on my model. It’s been a huge distraction but I built a 1/4 Hellcat RC plane at a friends shop and it was over 100 lbs so we can’t fly it because the weight limit is 55lbs for airplanes without a waiver which we can’t get because there aren’t any locals that can give us and inspection. I suffer very badly from wanting to build more than one model at a time but I’ll try to stick to one at a time moving forward, lol.
- mark j. radick
- Has liked: 394 times
- Been liked: 538 times
Re: Another Tiger
1/4 scale ! Nice ! hope you guys put a Moki radial engine in it ! Love the sound of the large radial's !
- Brian Ostlind
- Brian Ostlind
- Tim Page
- Has liked: 40 times
- Been liked: 471 times
Re: Another Tiger
Thanks for the video Brian.
It looks like one of those tasks where a bit of practice helps.
- Been liked: 54 times
Re: Another Tiger
Looking good. Don't forget to put zimmerit on the plate in front of the drivers visor and hull mg.
- Brian Ostlind
Re: Another Tiger
Hi Mike, although most modelers ad zim here I haven’t seen much evidence that this area was actually covered. I prefer the smooth look there.
I just don’t see it.
- Has liked: 316 times
- Been liked: 134 times
Re: Another Tiger
I have enjoyed watching this video, probably the first time applying zim coating on 1/6 scale panzer i have seen from youtube. Thanks for uploading this. Any progress of making your Panther 9&10?Brian Ostlind wrote: ↑Tue Feb 28, 2023 6:12 pmsome (not perfect) zimmerit.
although a year and a week later, a video!
Jae-seung
- Brian Ostlind
Re: Another Tiger
I thought the same thing and did not apply it there on my Tiger then I got this question from Per Sonnervik
"I have one question regarding your application of zimmerit; why no zimmerit on the plate in front of the drivers visor and MG? This plate was also zimmeritted, there are quite a lot of photos showing this. When one put zimmerit here one should not forget to do two parallel lines in the zimmerit, always in the same place in front of the front lamp. The same type of lines can be found on the Tiger II front , probably from sort of ladder contraption used when applying the zimmerit."
If you look at picture 2 you posted it has zimmerit there and you can see the 2 lines that Per mentions.
I am pretty sure there is also zimmerit on the 1st and 3rd picture, at that angle it is hard to tell.
- Has liked: 166 times
- Been liked: 849 times
Re: Another Tiger
Looks really good Brian. I like your chips and scuff areas - once painted and weathered this will look great!
As for the area in front of drivers plate - if that did have zimmerit it would get worn quickly from the Driver and Radio Operator walking on it to get in and out of the tank. So in short order it would look like there's none there,
- Has liked: 6 times
- Been liked: 194 times
Re: Another Tiger
Hi all,
Yes, the horizontal front hull plate had zimmerit as Per described.
Hard to find good photos of it but here are some below.
It´s all in the details!
Re: Another Tiger
Hi again,
Here is a photo of a post war dug up Tiger 1 front plate showing tracers of once applied zimmerit.
Hope this was of any use.
