Still not much visual progress, my day job is quite intense these days, but still able squeeze inn some time to play with my little Tiger kit
Have spent several evenings on the OpenTx and Beier USM-RC-3 sound module. Blown away by the possibilities it gives. Especially love the sequence mode, hver you can get a lot of a actions and sound to happen with the flick of one switch. This module will give a lot of life to the model, and also give me the more adjustability for timing pneumatic recoil, sound and (The unspeakable
) fire&smoke from the barrel.
As you can see, I have been playing with Mr. Surfacer 500. Difficult to get a good shot of the intended casting surface effect, but you get an idea. Fun stuff to work with
Need to shoot a fine mist of primer before evaluation to see if I need to tone down the effect.
Have a bit of a snag on one of the motors
During my first bench test, I thought there was a throwout on one axle, and my dial has confirmed what I saw
. I dont think this is useable as is, given how thight the gear works
What do you guys think?
https://youtube.com/shorts/fzvqLn7ldGs?feature=share
https://youtube.com/shorts/QEd_YdUQ1Xs?feature=share
Also have a question on chamfering the drive sprockets. Any recommendations on angles/geometry of the teeths?
