Churchill Prototype
Forum for discussions relating to the Churchill
Charles A Stewart
Has liked: 510 times
Been liked: 928 times
Re: Churchill Prototype
Post by Charles A Stewart »
Thanks guys
How would a Churchill crew repair a broken track in the field?
They would not have had access to an angle grinder or welding equip.
I hope welding isn't required for the new kit.
Cheers Charles
Been liked: 3698 times
Welding the track pin retaining flange in place - starts at 1m 6 seconds
We will not expect people to weld the pins in place :D - instead we will use a lightly knurled track pin and a grub screw.
The complete model:
Alex Easten
Has liked: 244 times
Been liked: 217 times
Post by Alex Easten »
Looks great!
Any chance of optional barrels? Such as long 6 pounder or 75mm for Churchill MIII*?
Alex
Quicquid agas age
GlenStenhouse
Has liked: 17 times
Been liked: 26 times
Post by GlenStenhouse »
Or a no turret option so an engineering bridge laying version can be built.
Alex Easten
While we're waiting for the order book and the even longer wait for delivery, could we have a few more images of the model please! :D
Alex
Quicquid agas age
Orders are finally open!
You will need to email us to reserve yours, as we have not update the website yet and this will take a few more days.
Here is the latest look at the Churchill Mk III. You will notice some changes compared with the previous render, and there will be a could more changes going on - visible and not so visible.
We made this today - Exhaust Outlet - part number EX0634 for the Churchill.
The image below shows the actual part on a MkIV Churchill at the Tank Museum in Bovington and the part that we made.
Churchill tracks - to avoid people having to weld plates on the links to hold the pins in place (like the real thing :o ) - the track pins are are knurled at one end. As a belt and braces approach we also have a grub screw that will lock the pin in place.
A_IMG_2028 (640 x 480).JPG (215.94 KiB) Viewed 4720 times
A_IMG_2026 (640 x 480).JPG (179.14 KiB) Viewed 4720 times
Progress on the Churchill
A_IMG_1900 (640 x 480).JPG (256.9 KiB) Viewed 4720 times
A_IMG_2003 (640 x 480).JPG (198.18 KiB) Viewed 4720 times
A_IMG_2004 (640 x 480).JPG (238.83 KiB) Viewed 4720 times
A_IMG_2005 (640 x 480).JPG (175 KiB) Viewed 4720 times
Engine air intakes for the Mk III - these went through several changes during the evolution of the Churchill Tank
A_IMG_2061 (640 x 480).JPG (189.67 KiB) Viewed 4721 times
A_IMG_2036 (640 x 480).JPG (162.08 KiB) Viewed 4721 times
Front and front deck of the Churchill. Almost complete - just need to add in the lights and hull mounted machine gun - which will be animated with a servo.
A_IMG_2037 (640 x 480).JPG (260.75 KiB) Viewed 4721 times
A_IMG_2034 (640 x 480).JPG (202.64 KiB) Viewed 4721 times
In the image below you can also see the turret floor going in and the mounting brackets for the the main gun mount.
A_IMG_2054 (640 x 480).JPG (189.81 KiB) Viewed 4721 times
Rear deck details on the Churchill. Pretty much complete at this stage.
A_IMG_2052 (640 x 480).JPG (182.79 KiB) Viewed 4715 times
A_IMG_2063 (640 x 480).JPG (181.94 KiB) Viewed 4715 times
A_IMG_2053 (640 x 480).JPG (182.3 KiB) Viewed 4715 times
A_IMG_2062 (640 x 480).JPG (189.14 KiB) Viewed 4715 times
Turret bin - bent and welded. Needs the lid and a couple of fire extinguishers.
A_IMG_2056 (640 x 480).JPG (187.46 KiB) Viewed 4716 times
Front and rear mudguards - also bent and welded steel.
A_IMG_2059 (640 x 480).JPG (169.3 KiB) Viewed 4716 times
A_IMG_2057 (640 x 480).JPG (181.5 KiB) Viewed 4716 times
A_IMG_2051 (640 x 480).JPG (180.24 KiB) Viewed 4716 times
