Agree, always love to see the suspension in action. but
I'm not a fan of missing bits either unless it's period, Tiger's with purposely missing front road wheels for the Russian winter or the perfect example, Stephen White's Cent adapted to historical harsh environment.
Missing bits or heavy battle damage models, I always think they are reserved for the Static Brigade.
Who wants to see a limping model tank traveling around and coming back after that, abused
I haven't fitted my bogies due to the weight, knowing I'd have to move the hull round several times on the bench, it sits on a little wheeled dolly trolley which allows with a little effort a 180 degree spin.
I don't know if the Bogie geometry is correct or not, probably wouldn't understand if it was explained to me either.
Early on, other modelers tried to get more "correct" travel by hollowing out the bogie frame tunnel, I did a couple of simple things including extending the tie rods about 10 mm, that helps prevent the springs from falling out when the bogie is not under tension. (Track removal)
Not sure what the final outcome will be.
On a serious note, I believe some Chieftain builders have experience scrubbing on the inside of the road tyres from the bolt heads on the shirt brackets.
Beware.
Another one for Adrian
