Pak 43/41 rebuild
- Has liked: 20 times
- Been liked: 737 times
Pak 43/41 rebuild
Hi all it’s been a while since I finished my 25 pounder, and was looking for a project, and acquired a built example, this has been dismantled, and my aim is to make as many functional parts out of brass steel and alloy, and of course plenty of fun.
Started on the slide, not sure if this model came with recoil, as It did not come with any assembly instructions, recoil made and the front stop plate altered and now secured with working side bolts Regards Jeff
Re: Pak 43/41 rebuild
Replaced the kit part for the barrel lock, with a more prototypical part, multi piece silver soldered together, still covered in fire scale and loosely fitted, will clean and rivet tomorrow
Regards Jeff-
Hi does anyone know how the firing mechanism worked on the Pak 43/41, there is very little detail that I can find, I know the firing button was on the centre of the left hand elevation wheel, but cannot see how it activated the firing pin
Regards Jeff
Regards Jeff
Started some work on the breech block, would have loved to be able to open the breech using the handle in a clockwise half turn, that’s not going to happen, so plan B, there is very little information on the workings of the breech, I assume the long cylinder on the left is for self cocking or locking as the front pawl engages with a pin, I am making what I think it should be, and have positioned it so I can still use the breech handle, this is how far I got today
Regards Jeff-
Bit more done today, reduced the width of the barrel collar by 7mm and altered the side lugs, right hand side narrower and left hand side larger to take the pivot arm, gun looks a mess at the moment, but will wait till all is working to put right
Regards Jeff-
Bit more done today, the bits are not hard to make, what takes the time in insuring all the bits end up in the right place, recoil now looks good with the pivot arm running along the beam, still work to do on beam with fixings and arm stop
Regards Jeff-
After I worked out the correct position of the beam, I made all the parts so it could be bolted in place, happy with the result, now on to the next challenge
Regards Jeff
[attachment=3]97E5BE30-5D14-4F8E-B821-7612B763C1CC.jpeg[/attachment
Regards Jeff
Only had an hour this evening, but now have the assembly instructions, started on page 1 with the wheels, got rid of the Allen key bolts and replaced with 6ba, castellated the nuts on to the next wheel
Regards Jeff-
- Has liked: 135 times
- Been liked: 792 times
This will be another stunning model once you work your magic. Lovely details Jeff!
B
B
Thanks Bob, I am looking forward to see what I can do with the detail on this, it makes the 25 pounder look like a pea shooter
Hope you are keeping well
Regards Jeff
Regards Jeff
While waiting for some brass to arrive, I had a go at making the foot release bolt for the trail arm, working ok just need to make the foot pedal
Regards Jeff-
Remade the sprung locking bolts for the trails and added the foot release pedal, used a 12 inch figure to check the dimensions looked right and they were working
Regards Jeff-
Bit more detail added, have shown a before and after picture, as I am sure a lot of the details are meaningless unless you have a 43/41
Regards Jeff-
Not much done today, but made and fitted the stops for the trails
Regards Jeff
