Martin's StuG 3
florian rudolf
Has liked: 294 times
Been liked: 639 times
Re: Martin's StuG 3
Post by florian rudolf »
It's realy a great building blog.
I'm watching to kopy something, but thinking every time about if it is usabal for the real 'life' in terrain or maybe is it a statik model?
I think less details looks not so good, but too much is useless. - I had this by building my PAK with the Armorpax details.
cheers
Florian
David Battson
Has liked: 114 times
Been liked: 244 times
Re: Martin's StuG 3
Post by David Battson »
Hi Martin, superb detailing work especially all those lock washers. From experience, they can be quite difficult to bend tightly against small bolt heads, especially when the bolts are only cosmetic and not screwed firmly in place. As a tip, if you anneal the brass lock tabs before fitting, they will be nice and soft and bend over more easily like paper. To anneal the brass lock tabs, just give them a very quick flash over with a blow torch and the absolute moment they go red, remove the heat - any more and you will melt them ! No need to quench in cold water, as soon as they are cool you can use them.
Keep up the good work
Martin Hofmann
Has liked: 148 times
Been liked: 1859 times
Re: Martin's StuG 3
Post by Martin Hofmann »
Hi Robert, Florian and David,
many thanks for your nice words.
Florian: it is not a static model. The StuG will come to life :D :D
David: many thanks for your help of bending the lock washers, but they are only 0,2mm thick brass plates and so they could be bending very good with sharp edges. The problem of the flame is, that the pressure of the gas have more power with the flame, than the washers are weighing and so the washers will fly away. :roll: :roll:
Here some more photos of the bump stops
Regards Martin
florian rudolf
Re: Martin's StuG 3
Martin,
like to see this great build model soon in real.
How did you make the drass covers? Do you have made a press tool for that? - If yes how it looks like? - It looks like ab chain loop?! ;)
Chers
Florian
yves mouton
Been liked: 580 times
Re: Martin's StuG 3
Post by yves mouton »
Hello Martin,
Very nice work on the hydrolic cylinders,
thats gonna be a awesome stug 8)
best regards Yves
Martin Hofmann
Re: Martin's StuG 3
Hi Florian and Yves,
thanks for your nice words. Florian: on the first photo you can see the "tool" for the brass plates. It is only a flattened tube, and all you have to do, is tap the 0,3mm thick sheet on a soft surface. Also here some more photos of the casting parts for the return rollers.
Regards Martin
florian rudolf
Re: Martin's StuG 3
Perfect work Martin.
Thanks for your tip :wink:
Martin Hofmann
Re: Martin's StuG 3
Thanks Florian,
here are the bump stops and the holders with some primer and the new holders on the covers for the vent covers incl. the beautiful hinges from Mark Lawson - with some small modifications.
Regards Martin
Robert Tanzer
Has liked: 1037 times
Been liked: 903 times
Re: Martin's StuG 3
Post by Robert Tanzer »
I realy love to follow your build, well done.
Robert
Martin Hofmann
Re: Martin's StuG 3
Thanks Robert,
here is a little update from the return rollers with grease nipples, the vent cover with modified corners and the holder for the spare wheel and also the first parts of the cannon with some welds.
Regards Martin
Björn Johansson
Has liked: 467 times
Been liked: 406 times
Re: Martin's StuG 3
Post by Björn Johansson »
Lovely !!
Kind regards from Björn
Martin Hofmann
Re: Martin's StuG 3
Thanks Björn,
here are some more fotos with preparing the welds in the air intake, motor cover, main compartment and barrel. Also modified the cover for the commander.
Regards Martin
Steen Vøler
Has liked: 62 times
Been liked: 498 times
Re: Martin's StuG 3
Post by Steen Vøler »
Hi Martin
What technique did you use to cut the commanders hatch. A small saw or ?
cheers
Steen
Steen Vøler
Has liked: 62 times
Re: Martin's StuG 3
Hi Martin
cheers
Steen
Martin Hofmann
Re: Martin's StuG 3
Hi Steen,
i took a scriber and scratch the surface to simulate a saw-cut.
And what can i say - the fake is functioned. :D :D :D
Regards Martin
