Martin's StuG 3
- Martin Hofmann
- Has liked: 151 times
- Been liked: 2014 times
Re: Martin's StuG 3
Now it is time for the next small update.
I had primed the sprockets and made some modifications on the idler wheels.
Regards Martin
- Has liked: 749 times
- Been liked: 360 times
Re: Martin's StuG 3
Beautiful - wow!
Did you actually machine them, or was this a matter of lots of elbow grease?
- Has liked: 297 times
- Been liked: 645 times
- Martin Hofmann
Re: Martin's StuG 3
Hi Chris,
hi Florian,
thank you for the compliments. Chris: i had worked some hours with the Dremel
And so much welds to make...........
hi Florian,
Regards Martin
- Martin Hofmann
Re: Martin's StuG 3
some more progress at the final drives with the oil drain plugs, the casting surfaces and the swing arms with their modifications
Regards Martin
- Has liked: 481 times
- Been liked: 408 times
- Martin Hofmann
Re: Martin's StuG 3
Hi Florian,
Hi Björn,
thank you very much for your nice words. And welcome Björn to the world of tanks.
Sorry for late answering but i am very busy at the moment.
Here are some new photos of the hub caps with some modifications: thicker cap with new radius, safety plates for the screws and the new flat grease nipple. That is a cap screw M1,6 with nut, glued a ball in it with dia of 1,5mm and glued a washer in front to simulate the nipple so you can see the ball
Hi Björn,
Regards Martin
- Been liked: 741 times
Re: Martin's StuG 3
I love those grease fittings! They look like they actually work.
Re: Martin's StuG 3
Thats so beautifull, awesome detail work. Love it!
Now you must do the grease gun for those tank mechanics also
Kind regards from Björn
- Has liked: 1131 times
- Been liked: 990 times
- Martin Hofmann
Re: Martin's StuG 3
Hi Yves, Florian, Chris, Björn and Robert,
many many thanks for your compliments, but that was only the first of some more modifications of the covers, bump stops and their holders.
Here comes the next photos of the result.
Regards Martin
