RT Late Tiger One
- Has liked: 1123 times
- Been liked: 990 times
Re: RT Late Tiger One
Did a try and paint the back wall with eggwithe, dont know if it is accurate.
Please let me know.
Robert
Please let me know.
Robert
- Has liked: 749 times
- Been liked: 360 times
That is SO coool!
Making decent periscopes/episcopes is a science per se and what you are pulling off might just be the best solution to date! Some need just two - others more, like, seven.
The late Mike Stannard had an option of optical glass prisms for his periscope sets. I always thought that to be the absolute, ultimate. There has also been a resin option, pretty blurred, or even milky. The way you do this is very down to business, especially if there is no need for internal detail.
Very exciting, indeed!
Started to make the jack holders on my Tiger. A bit fiddly, drillbit is 0.8mm. And a working wingnut.
- Has liked: 794 times
I drilled them to M1,4Vince Cutajar wrote: ↑Thu Feb 11, 2021 8:22 pmThat jack holder is looking good Robert. What size is that wing nut?
Today in my mancave.
Test fitted the 20ton jack in place.
And it fit.
Tomorrow I will cut and solder the brass pinns so they dont
falls out.
And it fit.
falls out.
Today I started to fix the engine hatch also on my Tiger.
Have to use my resin printer also
But slowly I am getting there.
Stay safe all of you.
Robert
Robert
- Been liked: 1767 times
Made some improvement on my Tiger.
The new filling caps are in place.
Did also countersunk all screws on engine deck. Looks more realistic I think.
And did a bit work on the the square screws which I thought were a bit on the larged side.
Robert is full of ideas. Here you get a glimpse of his DIY, foldable spray paint booth. Nifty idea!
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
