Steve does another Elefant
Steve Norris
Has liked: 8 times
Been liked: 697 times
Post by Steve Norris »
This is my 3rd Elefant build, the first 2 being commission builds.
This one will have as much detail added as possible without going daft.
The lower hull has been detailed , not 100% but good enough.
A good start, plenty more to do
Robert Reid
Has liked: 99 times
Been liked: 446 times
Re: Steve does another Elefant
Post by Robert Reid »
You lost me at the phrase "... without going daft."
Isn't that why we're all here?
Looking forward to seeing this one unfold. Love to see the kinds of amazing things folks get up to here!
RPR
Been liked: 1783 times
We're all daft otherwise we wouldn't be here. :D
Looking forward to a superb build :mrgreen:
Has liked: 129 times
Been liked: 772 times
Steve,
Following with interest - your builds are always great references. I will enjoy what details you add and share!
Steve Norris
Has liked: 8 times
Some more Elefant progress.
The basic hull goes together very nicely, just a bit of tweaking required on the rear fillet pieces.
A counter sunk screw was added to the back end of each fillet piece to add a bit of extra rigidity.
Overall view of the assembled lower hull, the fit of all the parts was very good with virtually no adjustments required.
The mudguards will have diamond tread plate added when complete. The forward section has been put in place as a trial fit
Suspension units ready to fit
Wheels painted and ready to fit
More to follow.
Steve Norris
Has liked: 8 times
Lower hull now complete with paint.
Time to flip it the right way up and start the upper hull.
Steve Norris
Has liked: 8 times
Some more progress, suspension fitted along with wheels and tracks.
The tracks came out nice after a coat of primer and a couple of coats of paint.
Time to start the upper hull.
Steen Vøler
Has liked: 62 times
Been liked: 498 times
Post by Steen Vøler »
Very nice indeed :D
Can I ask what color you have used for the tracks. Looks really good
cheers
Steen
Steve Norris
Has liked: 8 times
Hi Steen.
The tracks were etch primed using Upol acid etch grey the lightly coated in Halfords red oxide followed by a dusting of Halfords Matt black. A further dusting of dark metallic gray and when dry a wash with Vallejo dark brown.
I am very pleased myself with the way they turned out.
Steen Vøler
Has liked: 62 times
Thanks Steve
The tracks are really good looking 😃
cheers
Steen
Has liked: 2267 times
Been liked: 7152 times
Steve you are the "elephant man" lol. Lovely work as usual! 8)
Steve Norris
Has liked: 8 times
Plenty of weld seams on this tank !
Look at the thickness of the armour with the additional plate added
No additional armour on the lower plate
The cone headed bolts securing the additional armour will be added after the zimmerit has been applied.
Steve Norris
Has liked: 8 times
Sunday’s update,
More detail added and the Zimmerit is now done on the front end.
I need to find a way to simulate the remains of the welds on the horizontal plate, were the jack stowage used to be.
Looking very good Steve. Ref the old Jack mount welds, you need to put it all together add the welds and then remove it leaving behind the scars, that's the only way I know. 8)
Steve Norris
Has liked: 8 times
Hi Phil
Good idea, I will make up a couple of dummy jack bases to act as templates.
