Steve does another Elefant
- Has liked: 8 times
- Been liked: 701 times
This is my 3rd Elefant build, the first 2 being commission builds.
This one will have as much detail added as possible without going daft.
The lower hull has been detailed , not 100% but good enough. Regards
- Has liked: 99 times
- Been liked: 446 times
Re: Steve does another Elefant
You lost me at the phrase "... without going daft."
Isn't that why we're all here?
Looking forward to seeing this one unfold. Love to see the kinds of amazing things folks get up to here!
RPR
RPR
- Been liked: 1839 times
We're all daft otherwise we wouldn't be here.
Looking forward to a superb build
- Has liked: 161 times
- Been liked: 830 times
Steve,
Following with interest - your builds are always great references. I will enjoy what details you add and share!
Some more Elefant progress.
The basic hull goes together very nicely, just a bit of tweaking required on the rear fillet pieces.
More to follow.
More to follow.
Lower hull now complete with paint.
Time to flip it the right way up and start the upper hull.
Some more progress, suspension fitted along with wheels and tracks.
Time to start the upper hull.
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
Very nice indeed
Can I ask what color you have used for the tracks. Looks really good
cheers
Steen
Steen
Hi Steen.
The tracks were etch primed using Upol acid etch grey the lightly coated in Halfords red oxide followed by a dusting of Halfords Matt black. A further dusting of dark metallic gray and when dry a wash with Vallejo dark brown.
I am very pleased myself with the way they turned out.
- Steen Vøler
- Has liked: 2280 times
- Been liked: 7192 times
Steve you are the "elephant man" lol. Lovely work as usual!
Plenty of weld seams on this tank !
The cone headed bolts securing the additional armour will be added after the zimmerit has been applied.
Sunday’s update,
I need to find a way to simulate the remains of the welds on the horizontal plate, were the jack stowage used to be.
Looking very good Steve. Ref the old Jack mount welds, you need to put it all together add the welds and then remove it leaving behind the scars, that's the only way I know.
Hi Phil
Good idea, I will make up a couple of dummy jack bases to act as templates.
