Martin's Elefant
Has liked: 1469 times
Been liked: 1642 times
Re: Martin's Elefant
I love the 'home made' hinges :D
How did you solder them (soft or silver) and how did you hold them, as the tube muss federleicht sein ?
Sorry Derek, just trying out Google translate :wink: (federleicht = light as a feather. Hopefully)
Martin Hofmann
Has liked: 150 times
Been liked: 1958 times
Post by Martin Hofmann »
Hi Derek,
hi Adrian,
sorry for talking a little german with german people - i know it is an english spoken forum. :lol: :lol:
Adrian: i soft soldered the hinges in a simple self made jig. The diameter of the tube is 0,2mm bigger than the new bolt. I also built by myself. Photos will follow soon, because i am very busy at the moment with my new baby: Ivanos HL 230 P45.
Regards Martin
Martin Hofmann
Hi Adrian,
here comes the simulated photo of the simple jig for soldering the hinges. At the time of soldering, the parts where "naked".
Also you can see the new pins for the hinges with a diameter of 2mm. It is very near to the origin dimensions.
Regards Martin
Thanks Martin.
It looks easy when you show it like that :lol: :lol: :lol:
Martin Hofmann
After a long time here comes an update with the new mud scrapers, the towing hook and some mounted road wheels onto the hull.
Regards Martin
Martin Hofmann
After a very very long time here is the next update of the roof and the bottom plate with some weathering.
After some weathering the bottom absolut looks like other than before.
Regards Martin
Martin Hofmann
Now i start the building process of the hull. Slowly it looks like an Elefant.
Chang: thank you very much for the information of the diamond plates i bought in UK!!!
Regards Martin
Martin Hofmann
Here comes some new impressions from the Notek light.
This got an LED for two different colors of light. Seen on the last photos.
Regards Martin
Martin Hofmann
I think it is time for more updates in this built.
Here are some more photos of the hull with the new holders for the mud guard and all the new cable holders.
Regards Martin
Martin Hofmann
Here are some more photos of the side wall with all welding seams on the holders.
The angles on the front side got 2 slots for 2 pins, they are soldered in to give more strongness to the angle after gluing into the holes for the pins - seen on the last 3 photos.
Regards Martin
Wonderful work as always Martin :!:
And thanks for taking the time to take all the pictures :D
Derek Attree
Has liked: 219 times
Been liked: 198 times
Post by Derek Attree »
Hi Martin
Loving this build .
Has liked: 151 times
Been liked: 822 times
Hi Martin,
I'm enjoying your detail parts making. You make your brackets and hooks very robust! Really nice work! Thanks for posting!
B
Martin Hofmann
Hi Adrian, Derek and Bob,
many thanks for your kind words. Now it is time to make the Zimmerit onto the walls.
It's a time consuming job with Milliput, but it looks fine.
Regards Martin
Been liked: 1732 times
Excellent attention to detail, the Zimmerit around the pistol port is tricky, regards simon.
