Cheers in advance
Rivet tool
- Been liked: 83 times
Rivet tool
I'm about to rivet the 1mm rivets to the bin lids,could anyone recommends a riveting tool to do the job? All of the rivet gun's minimum rivet size is 3mm.
Cheers in advance
Cheers in advance
- Steve Lewington
- Has liked: 8817 times
- Been liked: 319 times
Re: Rivet tool
Hi Manny
Try rivet snaps buy two that are a suitable size for the rivets you are using.
The best place to buy then is E-BAY
Hope this is of help to you.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
No respite.
No forgiveness.
- Has liked: 1470 times
- Been liked: 1643 times
Re: Rivet tool
3/64" is 1.2mm, so might be OK.
Ebay item 330703010063
- Been liked: 3666 times
Re: Rivet tool
May be stating the obvious, but the rivets do not need to be "riveted" . A dab of industrial strength glue and some pliers to snip the protruding part internally would do the trick as well.
- Has liked: 10 times
- Been liked: 224 times
Re: Rivet tool
What's wrong with a hammer and dolly. I did all the rivets on my 251 that way.
Dennis.
Dennis.
