Tiger1 " tard-mid" !!??
Ivano Costantini
Been liked: 735 times
Re: Tiger1 " tard-mid" !!??
Post by Ivano Costantini »
I took courage and applied the zimmerit to the back of the turret, what do you think?
Has liked: 792 times
Looks good. Are you using milliput?
Ivano Costantini
Hi Vince
I am using an old two-component filler that I forgot to have, similar to milliput but from my most resistant experience. I think when it is painted it will be fine, otherwise it will be fine anyway! Ha ha ha ha ha!
Today I continue, but I don't think I can finish it, it's a long job.
Ivano Costantini
I would like to put the tank on the Eastern front, I read that the "Totenkopf" division in February 1944 was in central Ukraine, so it should be fine. Please, can you tell me what numbering the "companies" had? Which department sign was painted on the tank (skull)? What colors did the numbers and the sign have? Thank you
Ivano Costantini
Made a second hole in the cloak.
Modified swelling profile.
Now I have to redo the internal parts of the hole, so I will have to redo the biocular optics. I hope someone has some photos otherwise I will have to improvise some parts.
Did you receive the emails I sent you?
Ivano Costantini
Yes, thank you, but I also replied by email
Did not get the email reply.
Ivano Costantini
I sent it at 12.09.
I send it back
Ivano Costantini
However, I just wanted to ask you if I have anything to understand this drawing
thank you
TZF 9b 6.jpg (77.66 KiB) Viewed 2607 times
Sorry Ivano but I have no idea about that part. In fact it is also shown in the second diagram I sent. Could it be just a simple handle? Just an idea.
Ivano Costantini
I found the documentation I was looking for to reproduce the biocular viewer. Could anyone give me the measurement between the two holes (wheelbase) in the Armortek tank? Thanks a lot Ivano
Ivano Costantini
I finished applying the zimmerit on the turret.
Do you think these surface damages are realistic? I don't want to attack metal. Do they look like real? Thank
Ivano Costantini
It's not finished, it's not perfect, I did it "freehand"
