Florians FAMO build
- Been liked: 1767 times
Re: Florians FAMO build
Lovely job Florian, i am taking some tips on this build, regards simon manning.
- Has liked: 297 times
- Been liked: 645 times
Good morning Simon,
glad to can help you. May you post some photos of your work
Some more details on my Famo. Many thanks to Michal for his great work at the lightning...
With a bit more detailing work, the Famo is getting better and better. So I installed some more rivets in the loading area.
The electronic parts for the switch and controle panel is nearly finish installed. For switching the main electric I installed 2, 150A relais. One for the engine controler, and one for the other electrik. So I can switch it seperatly with smaler switches. For the safety I installed one 125A fuse for the engine controler an one 20A for the rest.
Excellent work Florian, keep the posts coming as its very interesting, how are those tracks now?
Good morning Phil,
thank you....
Did'nt check the tracks in the field till now.Only on the street and it looks much better on this ground. So I think at the field its the same. I'll be back for that answer
thank you....
Hello guys,
yes I am still alive. Had much other things to do, so I could'nt work on the Famo. Fortunatly the weather is going sick, so I will do something inside.
I ordered some parts and plan some special
At first I ordered a kit for my powerpack to build.
Its LiFePo4 with 10Ah. I think thats enough power for the Famo and the battery is also not so heavy.
- Been liked: 35 times
I have used LiFe batteries for years in R/C helicopters and cars, a lot lighter than traditional batteries and can be fast charged at 3 times their rate, don't see why a lot more people don't use them, Oh by the way, nice build!
Starting to look good Florian, not enough Famo's on here, thanks for posting, regards simon.
Yes indeed. the LiFe Power is awesome.
Well in the last view days I did some work on the batery box. what would you think it going to bee? - Tipp its from a movie... The original Famo i mkae was in north Africa
- 20191102_130727.jpg (39.08 KiB) Viewed 5568 times
- 20191102_130718.jpg (37.03 KiB) Viewed 5568 times
- 20191031_192323.jpg (55.82 KiB) Viewed 5568 times
- 20191102_130626.jpg (32.33 KiB) Viewed 5568 times
- 20191103_181944.jpg (85.17 KiB) Viewed 5568 times
- 20191031_192306.jpg (73.43 KiB) Viewed 5568 times
The next I made the lifter for this monster
- 20191102_102225.jpg (36.27 KiB) Viewed 5567 times
- 20191102_102213.jpg (30.45 KiB) Viewed 5567 times
- Has liked: 7 times
- Been liked: 46 times
Florian, that crate is excellent. No doubt you had some TOP MEN working on it!?
- Has liked: 792 times
What a beautiful wooden crate. Reminded me of the film "Raiders of the lost ark".
Yes thats ist.
I build all by my own all by my own
Than I know its right build
Last edited by florian rudolf on Fri Oct 15, 2021 8:45 am, edited 1 time in total.
