John’s Czech Hedgehog
All topics related to Armortek's Czech Hedgehog
John Heath
Has liked: 4 times
Been liked: 102 times
Post by John Heath »
Received the little hedgehog kit this morning. Looks a nice little “weekend” kit.Bought just the one for now to see what it’s like.
I’ll be finishing mine in the very dark blue as often used in the east rather than the beach brown.
Filling in the button head bolts with putty will be a bit tedious. Some experimenting to do texturing the finish and adding some rust on some scrap angle section.
John Heath
Has liked: 4 times
Re: John’s Czech Hedgehog
Assenbled and I think I’ve got the bolt pattern right. 🙏🏼
Also tested the textured paint on some scrap. Will look good once the final colour is applied and rusted a bit.
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
Not sure about the bolt pattern. You may need to Czech it :lol:
John Heath
Has liked: 4 times
The bolt patterns do seem to vary a lot. Found a photo of two sitting side by side and they had been bolted together differently. May make some minor changes and will be fitting a few hex head bolts as again found photos where a few hex head bolts had been used.
Two sections were fastened together in the factory and the third fitted in the field which would explain the differences.
Has liked: 1040 times
Mark, we may need to run that again....
The Czech's in the posts.
John Heath
Has liked: 4 times
Two photos. One is by Armortek and the other is mine. Which is which?
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Post by Brian Ostlind »
Looks like a nice kit. I need a couple of these!
John Heath
Has liked: 4 times
Applied putty to the button head bolts. A light sanding then ready for priming. Used Green Stuff putty which I find so much better than Milliput and much easier to work with. Could never go back to Milliput. Makes nice weld detail as well.
Fitted a few hex head bolts instead of the button head bolts. Found when researching the subject this happened quite often. Field repairs I assume.
John Heath
Has liked: 4 times
Just add rust. 😁
Primed, textured paint applied and the Tamiya matt paint mixed to the approximate shade of dark blue used in the east.Decided to not go with the brown as used on the beaches it is so commonly seen in models despite not being the colour used often inland. Work done in filling in the button head bolts was worth it.
Light rust to be applied and finished with matt clear.
John Heath
Has liked: 4 times
Not sure about the rust. May need a little bit more work.
John Heath
Has liked: 4 times
Not being happy with the rust decided to repaint in very dark blue. Looks almost black. I’ll leave it this way for a while while deciding what to do about rust.
Pete Nash
Has liked: 401 times
Been liked: 166 times
Post by Pete Nash »
Don't know about creating rust?
Leave it outside for a while, it will soon go rusty, and it will be proper rust, not simulated :) :lol:
John Heath
Has liked: 4 times
The multipurpose hedgehog. 😀
Has liked: 794 times
Love the idea. It's a good selling point.
Has liked: 1492 times
Been liked: 1699 times
I wonder if future orders will be shipped with 6 Armortek mugs :?:
Adrian
