Florians FAMO build
- Has liked: 749 times
- Been liked: 360 times
Re: Florians FAMO build
Clearly, you two must be the same person!
- Been liked: 1767 times
- Has liked: 297 times
- Been liked: 645 times
Hello Simon,
look at the post from Armortek at Militracks in Overloon.
Unfortunatly I have'nt been there at this time. Nex year I'll be there.
The first roll out.
I remember some problems at my Sdkfz251. The same I have with the FAMO.
I have to do some work at the track. Also some electrik problems, but nothing difficult.
So nice to see your Famo out in the sunshine, she's looking good
- Chang
- Has liked: 16585 times
- Been liked: 487 times
Hi Phil,florian rudolf wrote: ↑Mon May 27, 2019 12:08 pmThe first roll out.
The FAMO looks good.
I reckon two 12V batteries were laid on the cargo area. Is there any photo of them?
With regards,
Lerh Chang
Hello Chang,
I make another solution with the battery. In one of the stowage boxes are the switches, the other one get the 'original' inside...
Thanks Phil,
yes it looking good outside... - It gives me a push to do something on the FAMO to finish this year
- Chang
Hi Phil,florian rudolf wrote: ↑Tue May 28, 2019 7:41 amHello Chang,
I make another solution with the battery. In one of the stowage boxes are the switches, the other one get the 'original' inside...![]()
Thanks for the reply.
Not sure if I misunderstood your meaning. How are two of 12V batteries able to be squeezed into the other storage box?
Regards,
its only one 12V akku each stowage box. This are smale LiFePo accus I think. With only 6 or 7 Ah.
I want ti install an 24V / 12Ah accu.
Florian
Florian
I had some time to build a little more details on my FAMO.
so I made the frame for the drivers seat, and while having a good friend is saddler, I've got some thin leather in the right color for the poetry between the fire panel and hood...
At my first roll out I noticed some problems with the track. The same I had with my SdKfz 251. So I have to modify my track a bit.
Some more details finised and fixed at the model.
If my modified tracks are complete and at work, I'll make some photos of that.
A little work on the fenders. I milled the alu at the middle section so it looks some more scale. The weight I lost at this position I'll put later into the engine dummy. You need the weight because the steering function on slippy bottom.
Some work on the loading area and fenders.
The fenders instalation is quite difficult, because a long part with some fasteners to fix. - So if one part does'nt haf the rigt position in a bit of a mm, you can't get it fixed.
Now my loading area and fenders come together on the famo and looks amazing.
