Hi Guys
I have started to build my Tiger 131 and come up against a problem bench testing the drive system.
I am using a JR DSX 9 II radio and Spektrum AR610 Receiver as recommended by Armortek
I have set up the radio for Delta wing (elevon) and hooked up the audio module input 1 to Elevator and Input 4 to Aileron on the receiver.
Audio Module output 3 to Motion Control Module 3 and
Audio output 5 to Motion control 4.
Audio control output 6 to Gear for now to test.
The motors are wired as is the sound module as above and to the power input
The Receiver was bound to the radio prior to this setup and tested with servos so i know the receiver works.
now when i switch on the by the remote module i get a single squek from the speaker. and no drive at all?
when operation the radio the relays can be heard switching and also the Motor led's D1 & D2 brighten and come to rest dull glow when the sticks are still.
Any ideas where i am going wrong anyone please??
Andy
Tiger 131 in West Sussex
- andymusgrove
- Has liked: 197 times
- Been liked: 89 times
- andymusgrove
Re: Tiger 131 in West Sussex
Further to this i have taken the Audio module out of the equation and get the same results??
Batteries are fully charged - tested all the fuses all ok..
Very frustrating
Very frustrating
- Has liked: 1484 times
- Been liked: 1687 times
Do you have access to a volt meter ? Do you get a voltage between the sets of blue and yellow leads for the motors ?
How are your DIP switches currently set ?
If the LEDs are changing, then it looks like the radio side is setup OK.
- andymusgrove
Hi Adrian
Ok good idea i will test the output at the Motion control Terminals
The dip switches are all down, i did try Dip sw 1 up and it made no difference
ill go test the outputs now.
Thanks for your reply
Andy
Andy
According to the Elefant instructions, switch 4 should be ON (UP) for 60A output on Output 3 and OFF (DOWN) for 5A output.
That shouldn't stop the other track though.
- andymusgrove
i just checked output on both Left & right - nothing
also tried with Dip Sw 4 on still nothing
Motors tested and run ok on 12v
Looks like you've tested everything I would
The factory should be open again now, so probably best to give them a ring.
- andymusgrove
Ok thanks Adrian i will give them a call tomorrow - i Will psot their reply etc
Andy
Andy
- andymusgrove
Quick update, Sent the Motion Control unit back and was replaced within a couple of days all up and running nicely now
Thanks to the team at Armortek for their great service
