ELEFANTE
RCSparks
Has liked: 38 times
Been liked: 59 times
Re: ELEFANTE
Post by RCSparks »
WOW!! YOU ARE KILLING THIS BUILD!!
Really great job, and an amazing eye for detail.. The greatest thing about builds like this are how inspiring they are. Thank you for sharing!
RC in the Mornin', RC in the Evenin'!
Chang
Has liked: 16571 times
Been liked: 487 times
Re: ELEFANTE
Post by Chang »
Alberto Barba wrote:
Fri Dec 21, 2018 4:53 am
We remake the sliding cover for sight, to correct the posición of the hole for the sight and we make it in two pieces to allow open the gunner’s hatch... sorry I don’ know why the pictures do not show in the correct sequence
Hola Alberto,
LOve your adding details on the commander's hatch, and the correct arched two pieces of sliding cover with right position of the hole.
BTW, is the 88mm gun tube a new customer-made one? Looks a bit longer but is correct than the stock one.
Best regards, :D
Lerh Chang
Alberto Barba
Has liked: 9 times
Been liked: 124 times
Re: ELEFANTE
Post by Alberto Barba »
Hello !
Thank you very much RCSparks and Chang !, the barrel is the one of the kit, just is not in the final position yet :wink:
Well this are the final details of the roof and the mantlet corrected, rectified and texured no the edges...
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Sorry again for the pictures secuence...
Chang
Re: ELEFANTE
Post by Chang »
Hola Alberto,
Only found now from your photo, that there is no down rib on the mantlet.
I was always wondering why can't my Elefant low down much of the gun...
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Hi Chang !
Glad to help, check the screws of the mantlet too...
Cheers !
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Pistol port, in progress
Chang
Re: ELEFANTE
Post by Chang »
I only add a chain locked between two pistol port plungers, so any one of them can be opened without losing.
Not accurate in reality, but functional.
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Hello !
Thanks Chang, May be we only open one pistol port but yes we will use a chain too...
Continue from the top to the bottom here other details, the lifting hooks was enlarge, welds, and starting some battle damages...
Has liked: 2282 times
Been liked: 7196 times
Re: ELEFANTE
Very realistic battle damage Alberto, that's an addition that some builders can get terribly wrong but yours look great! 8)
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Hi !
Many thanks Phil...
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Hello again, let’s start with the details on the engine deck, handles, caps, hatch stoppers, etc.
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
The hatch stoppers are workable
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Detailing the hatches...
Alberto Barba
Has liked: 9 times
Re: ELEFANTE
Driver hatch periscope cover reworked and detailed
