PAK 43 2018 arrived in Denmark
Allan Carlsen
Been liked: 128 times
Post by Allan Carlsen »
Hello and good morning
Just arrived here in Copenhagen yesterday. :D
The next couple of days I will check to see if all the parts are in box. Lots of parts :shock:
pak 43 nr 1.JPG (56.84 KiB) Viewed 9569 times
pak 43 nr 2.JPG (65.82 KiB) Viewed 9569 times
pak 43 nr 3.JPG (80 KiB) Viewed 9569 times
florian rudolf
Has liked: 297 times
Been liked: 645 times
Re: PAK 43 2018 arrived in Denmark
Post by florian rudolf »
Hello,
its a nice modell you get to build.
Do it with the spirit of Armorpax.
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Nice Allan
will be good to see it at the battlefield in the spring :-)
cheers
Steen
Allan Carlsen
Hello all
Some update on Pak 43.
Pak 43 nr 5.JPG (61.31 KiB) Viewed 9380 times
Mamma Mia just 820 of rivet's
Pak 43 nr 6.JPG (84.96 KiB) Viewed 9380 times
Has liked: 794 times
Thanks for the update Allan.
Comparing the length of the barrel and the wheels to the kitchen sink gives a good idea of size. Never thought that it would be so big. Keep it up.
Tom Roslund
Has liked: 5 times
Been liked: 20 times
Post by Tom Roslund »
Hey Allan , you're going to enjoy the build. I recently completed mine with the Armorpax detail kit. It really helps the look, but definitely changes the challenge level. I'm still a rookie, but am learning fast. I found a turntable to be immensely helpful for building this beast. I built mine using some scrap chunks I milled to fit the chassis without interfering with the gun parts. I've still got the final details to finish, but need a break. :wink:
Tom
Allan Carlsen
Hi Tom
Very fine model. Nice Work. Do you have more Picture. ?
florian rudolf
I've build mine also with Armorpax parts. Looking realy good.
Unfortunatly you can't use all Armorpax details, otherwise the PAK wouln't run anymore. So you have to think about the using of that model.
You may have al look at my building report.
http://www.rag-mm.de/Forum/thread.php?t ... f49d0f0c3b
Tom Roslund
Has liked: 5 times
Yes Allan, I've got a few more. I'm just a bit disorganized, and haven't compiled them yet. I'll get some more posted. The details kit made for a fun and educational build. As Florian mentioned, some pieces will not allow the model to move in some of it's functions. The suspension lockout parts would not allow the gun to be towed and use the suspension, so I left them off. Was an interesting journey figuring out how they worked in reality! Also the traverse got blocked by the size of some resin details for the suspension, but I left them as I didn't feel like modifying as I'm not anticipating traversing the model. I also got a bit intense with hiding the most obvious screw heads that took away from the scale visuals. There was much countersinking and puttying over flat head screws. It does help if one's so inclined to clean up the details. And resin parts are certainly a delicate operation to manage!
Tom
Tom Roslund
Has liked: 5 times
In my goal of hiding screws, and keeping the model disassemble-able, I came up with this idea for the recoil compensator. I probably took it a bit far, but once I got it in my head, the mechanic in me wants to make things serviceable regardless :wink: . I added some small bolts for detail look, and used magnets and dowels to secure the unit to the main structure. I'm learning as I go...
Allan Carlsen
Hello all
Thanks Tom, very nice pictures you got there.
Here is a little update on my Pak 43. On Sunday the wheels will come on.
pak 43 nr. 5.JPG (68.26 KiB) Viewed 8928 times
pak 43 nr. 6.JPG (89.96 KiB) Viewed 8928 times
pak 43 nr. 7.JPG (77.99 KiB) Viewed 8928 times
pak 43 nr. 8.JPG (67.01 KiB) Viewed 8928 times
Tom Roslund
Has liked: 5 times
Wow, seems like a lifetime ago ! Here's my recoil spade mods. I took some artistic license and used Knupfer's threaded studs to show on the face of the spades. Seemed to flow better with all the other riveting, and a believable fastener compared to the kit screws.
Tom
Allan Carlsen
I have come a little further on my Pak 43.
Thanks to Florian & Tom, nice Picture, good details.
pak 43 nr. 9.JPG (81.29 KiB) Viewed 8794 times
pak 43 nr. 10.JPG (79.26 KiB) Viewed 8794 times
pak 43 nr. 11.JPG (82.5 KiB) Viewed 8794 times
pak 43 nr. 12.JPG (81.57 KiB) Viewed 8794 times
Allan Carlsen
Hello all
Some small update on Pak 43.
Thanks to Bryan for making great pictures with many good details. I couldn't get it together without his Pictures. :D
Some of the things teased and had to be separated again. :shock:
pak 43 nr. 13.JPG (60.97 KiB) Viewed 8633 times
pak 43 nr. 14.JPG (66.47 KiB) Viewed 8633 times
pak 43 nr. 15.JPG (65.66 KiB) Viewed 8633 times
Allan Carlsen
Hello all
I made the shield on my Pak 43 here in the last couple of days. Some hard Work. :shock:
pak 43 nr. 16.JPG (55.88 KiB) Viewed 8400 times
pak 43 nr. 17.JPG (58.69 KiB) Viewed 8400 times
pak 43 nr. 18.JPG (52.63 KiB) Viewed 8400 times
spacer teases a lot, it is the one that lies between the shields
pak 43 nr. 19.JPG (55.81 KiB) Viewed 8400 times
