- Brian Ostlind
- Has liked: 975 times
- Been liked: 2068 times
- Brian Ostlind
- Brian Ostlind
- Brian Ostlind
Need help: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Hi, what is this piece? I can not locate a reference in the manual!
Thanks in advance.
Thanks in advance.
- Has liked: 793 times
- Brian Ostlind
- Brian Ostlind
Weathering and Zimmerit: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
I am painting the exhaust pipes and testing new modeling clay for the zim.
- Has liked: 5 times
- Been liked: 67 times
Looks great!
I mounted all of my parts before applying zimmerit. If I had to do it again, I would NOT apply zim to the turret area where you hang the extra track links.
I sent you a couple of emails with videos attached of the tank in the snow. Once I aligned the tracks and tightened them, it works great in the snow, even on a side slope. I was still careful to not pick up any gravel or other debris that might block the running gear.
Cheers... Tom
Cheers... Tom
- Brian Ostlind
- Brian Ostlind
- Brian Ostlind
That's looking good. What's the name of the product you are using?
- Brian Ostlind
Your son does a better job than me!
I considered using tile adhesive but I happened to have some automotive body putty (Bondo or NAPA body filler) laying around, so I used it. With the amount of hardener I mixed with the base, I had about 20 minutes to work with it before it became unworkable.
So, I applied about a 4 x 6 inch square area at a time. The thickness varies from about 1/8 to 1/4 inch.
How long does it take for the tile adhesive to set up? Is it a water based product (easy to clean up) or other?
Tom
Tom
- Brian Ostlind
Yes it is water based and takes a couple hours to dry. I wiped it off after the first attempt with a wet rag and re did it.
