Tom OBrien
Has liked: 5 times
Been liked: 67 times
Post by Tom OBrien »
crap... can it be rotated?
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Post by Brian Ostlind »
I have heard all you have to do is edit the photo in your computer or crop it a little then do the attachment and it will appear correctly.
Tom OBrien
Has liked: 5 times
Here's another attempt at uploading a photo.
It shows the idler axle after removing 2mm inward toward the hull. Now, the tracks run center to the track horns. The tracks no longer ride onto the road wheels.
Tom OBrien
Has liked: 5 times
test after crop
ping.
Hey, I think I got it.
Brian Ostlind
You got it!
Brian Ostlind
Tow rope: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
I’m dipping the tow ropes in vinegar to see what happens...
Brian Ostlind
Engine deck...three types of primer. I just started using Upol on some aluminum parts. It’s very high quality I like it a lot. The fan nozzle on the upol is different and takes some getting used to.
Has liked: 794 times
Would love to see the result of dipping the tow cables in vinegar.
Brian Ostlind
They have been soaking all morning and they are bubbling and turning black.
Brian Ostlind
Tom OBrien
Has liked: 5 times
Brilliant idea!
All I did was paint them lightly with a black primer, wait a few seconds, and wipe off excess paint. Makes it look worn but I'll be the vinegar works better. If so, I'll try it on mine (even painted, it should still react).
Tom
Brian Ostlind
Dull red: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
TS-33 is nice.
Brian Ostlind
Tow rope after vinegar soak...
Brian Ostlind
Sprayed them with wd-4
That looks good. I think I will be doing the same. Did you leave them in the vinegar for 24 hours?
