Panther 112
Panther 112
Not a build thread but may be of interest.
My recently acquired Panther turret number 112 (thank you Chris) When I get a minuet I will be upgrading the electrics, there's a problem with the off side rear idler and the turret traverse is not working.
My plan is to address the above issues, it's very high spec with an 8 channel radio and was refurbished a while ago by one of the best builders on this forum.
I will add new speakers, the latest panther sounds, a high pressure smoker and a dedicated esc for the turret traverse motor, plus a few more bits and pieces I expect.
The Panther will be towed by the new Famo, recreating many of the photos that we have come to love with lots of video to (roll on the spring and summer of next year). I have already filmed the Panther returning from the battle field coming under small arms and mortar fire, this I shall post to Youtube as soon as the editing is complete.
Some stills of the VT and how she looks right now.
- Panther 4.jpg (73.74 KiB) Viewed 11300 times
- Panther 5.jpg (63.07 KiB) Viewed 11300 times
- Has liked: 264 times
- Been liked: 195 times
Re: Panther 112
Stills from the video.
Re: Panther 112
The video.
Re: Panther 112
Came across this Panther image that I've never seen before.
- Bundesarchiv_Bild_101I-696-0432-13,_Polen,_Panzer_V_'Panther'_auf_dem_Feld.2.jpg (19.52 KiB) Viewed 10773 times
Re: Panther 112
I've made a start on 112, greasing the final drives and general maintenance. this gives me an opportunity to look over the vehicle.
Re: Panther 112
As the weather is not good I'm in the tank shop working on the Panther running gear.
- Setting up the sprocket position, basically as i have said before, leave the taper lock lose and gently run the tracks around slowly and let the sprocket find it's own comfortable position, (within reason of course if it has a serious fault then fix that first) then tighten the taper lock but just check those last two road wheels are sitting equally between the track horns.
Re: Panther 112
This little beauty is just about ready, I have tidied the wiring, added heat shrink where necessary, it now has fully proportional turret traverse, some new track links here and there, the oily bits are oiled, the final drives have been packed with grease,all the lights are now working,all in all a very well put together late war Panther which now runs and drives perfectly
I will post on the for sale and wanted very soon, I need to drive it around for a while with a big smile on my face first!
Regards Phil.
Re: Panther 112
Some more photos. Panther film showing the polished middle wheel rims, don't paint or polish every one, be random.
- Brian Ostlind
- Has liked: 976 times
- Been liked: 2068 times
Re: Panther 112
The Panther is headed my way! I can’t wait to get my hands on it.
Does anyone know if these exhaust pipes are accurate. Or should it have spark arresting mufflers to be more accurate?
- Has liked: 8 times
- Been liked: 701 times
Re: Panther 112
Hi Brian
Congratulations on your purchase, it should be in really good condition after Phil has worked his magic on it.
The exhausts on late war Panthers varied, I think it was a matter of what was available in the parts bin at the factory when they were assembled. No need to change them but if you prefer the flame damping type you could put those on and it would still be correct.
- Has liked: 793 times
- Brian Ostlind
Re: Panther 112
A few pieces but none fully built. Anxious to get the panther before our snow is gone maybe I can do a snow camo.
- Chris Hall
- Has liked: 536 times
- Been liked: 686 times
Re: Panther 112
Brian -Brian Ostlind wrote: ↑Sun Mar 03, 2019 4:17 pmDoes anyone know if these exhaust pipes are accurate. Or should it have spark arresting mufflers to be more accurate ?
When I owned 112 it was definitely my intention to fit the flammenvernichter. It's been built with some very late (March - April 1945) adaptions, so I felt the exhaust guards would be 'right'. It's a personal choice thing though and, as Steve rightly says, there's a world of difference between what the textbooks say and Real Life ......
Another thing I was considering was swapping the rear wheels for the all-steel versions as used on the late Tiger 1. Another very late War adaption.
But, whatever you do, have fun with the old girl !
All the best,
- Brian Ostlind
Re: Panther 112
Chris it is my undersataning the steel Panther rims are different design than tiger steel wheels and to my knowledge AT hasn’t made panther steel rims. In any case it would be sweet if they did make them and the exhausts too.
