MG led’s - where to buy
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Hi tankers,
I would like to install led’s to the two mg’s in my tiger 1.
Anybody know where to buy and also how to connect these to the benedini mini would be appreciated :D
cheers
Steen
John Baldwin
Re: MG led’s - where to buy
Post by John Baldwin »
Steen,
You can check with Steve Winstone. He carries the barrels and led units,
Gerhard Michel
Has liked: 3 times
Been liked: 678 times
Post by Gerhard Michel »
Hi Steen,
I buy LEDs at the usual electronics mail order companies. Red ones need approx. 20 mA (maybe 2.5 volts). A perhaps necessary pre-resistor for all voltages can be calculated choosing these two values with the basic formula of electricity (U = R * I).
Unfortunately I don't know Benedini modules. The Beier module allows to choose the output voltages for each exit.
Gerhard
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Hi Steen,
With the Benedini TBS5 there were resistors included on the board but the Mini does not have them so you have to put external resistors in. The ultrabright 3mm leds are usually 2.5 volts and using the formula 50 x (Supply Voltage - Led voltage) = Required Resistor. So 50 X (5 - 2.5) = approx 125 ohms 1/8watt.
Hope this helps.
Just read Stephen's post and that's the company where I get my batteries, leds and resisIors from, very good prices.
Dennis.
Has liked: 1038 times
Steen
These people are experts in model electronics and especially lighting.
https://www.componentshop.co.uk
Regards.
