- Has liked: 161 times
- Been liked: 849 times
I too recommend resistance soldering. Micro-Mark has a relatively inexpensive unit:
https://www.micromark.com/Resistance-Soldering-Unit
But to do any real work with it you need the tweezer plier type tip:
https://www.micromark.com/Heavy-Duty-Soldering-Pliers
They used to sell the whole setup for less than $200 but I don't see it any more.
These machines are excellent where a torch is too much heat. It works great for heavier gage brass and steel.
I suppose you could make one, it is indeed just a big coil with screw lugs. You could possibly make a handset using graphite for the tips.
I like your mud flaps - I plan on making an attempt at using the kit parts as well. For the hold down its a spring loaded hook like is used on jeep hoods. One could possibly make them functional if you find a small enough coil spring. I thought about attempting one but haven't yet. Even David Byrdens site does not have much info on this hook - only the location of the base.
- Has liked: 794 times
Yes Bob that Micromark RSU is not that expensive but if I add the cost of a step down transformer (240V here), carriage and taxes the cost would double. I was pleasantly surprised in re-discovering the skill in using that old soldering iron. I found it quiet versatile after some practise. If anyone has got one, don't throw it away.
Regarding the mudguard hold downs, I guess it is going to be trying to copy one from photos. Due to the small size, I doubt I will be using a spring.
I am redoing the front mudguard slidebars but had to stop work on them as I need to receive some 2mm wingnuts I have on order before I can continue.
So, to pass the time, I worked on the front plate boss (CE0641). For various reasons I had already decided to remake them from scratch and give them the through hole and the correct angled top face.
Also today I received Mark's tapered stab antenna. Very well made and excellent packing. Thanks Mark. Just for fun I did a trial fit of the antenna (and Armorpax clamp) to Liam's rubber base and bolted to the hull roof.
Now I have to search for a particular post on the forum about the colour of the antenna. I can't remember if it should be black or the base colour of the tank. Can't remember where I saw it.
[marq=right]Cable colour coding[/marq]
I am putting this link here so that in the future it will be easier for me to find it.
viewtopic.php?f=2&t=7225&p=62591#p62591
Vince Fender looks good. Can you share where you found 2mm wingnuts? Knupfer has blank wing nuts that can be tapped. I'm not sure if they'd ship to US or not.
Yes Bob, those are the ones I am waiting for. I am hoping to receive them today. I have checked and I think they do deliver to the States. At least the USA is in their list of countries when one does the checkout.
- Been liked: 11 times
I got the American Beauty. It was around $500. Expensive but worth it. I got all the accessories.
I still have a long way to go to catch up to Stephen's skill level.
One problem is I have to go to my dryer plug to use it. My garage circuit doesn't have the amperage.
Still waiting for the wingnuts! So I can't finish off the front mudguards. So last weekend I thought I would attempt (emphasis on the attempt) making the hold down latches of the front mudguards from scratch. As a reference I am using the drawing on page 35 of the modeller's guide book. There are no dimensions on this drawing so it was all guesswork. Today I finished them.
And a temporary fit, holding the lower part with a tool to see how it looks.
The shaft has still to be shortened as I made it long on purpose. Now I need to decide if they are decent enough to add to the model.
- Has liked: 748 times
- Been liked: 360 times
- Been liked: 1767 times
the mudgaurd clamps look good vince, nice attempt, regards simon manning.
Thanks Simon. I suspect that the lower part of the catch (the part that is fixed to the side of the hull) is too big. What I might do is to actually attach them to the hull and see if my eyes get accustomed to them. I can always remove them and blank the 2mm tapped hole that it needs to be fixed to the hull.
Finally plucked up the courage to drill and hand tap (in situ) a 2mm hole to attach the mudguard catch to the hull. I managed to do it with the aid of a machine tapping guide and the best part was that I did not need to remove the sprocket.
I will leave them fixed for now to see if they "look right". At the moment I have a feeling they look a bit "chunky".
