Steves Elefant build
Been liked: 1768 times
Re: Steves Elefant build
looks superb steve, they are a very impressive vehicle when complete, a nice job, regards simon.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Basic camofauge has now been added to the fist Elefant
Little brother acting as a pattern above
Ray Brown
Has liked: 26 times
Been liked: 103 times
Post by Ray Brown »
looking good steve.
vincent hung shu yue
Been liked: 24 times
Post by vincent hung shu yue »
Hi Steve
Really good looking!
Vincent
Chang
Has liked: 16576 times
Been liked: 487 times
Post by Chang »
Hi Steve,
Two filler caps on the engine deck looks as the genuine parts. :shock:
Steve Norris
Has liked: 8 times
Hi Chang
These are modified Armorpax items, they do not come with the kit.
Steve Norris
Has liked: 8 times
Almost there.
The first of 2 Elefant builds is now nearing the end, electrics all sorted and just the final bits and pieces to complete.
Must say I do like the twin engine start sound supplied with the sound module.
Almost ready for its new owner
nikolas george
Has liked: 52 times
Been liked: 13 times
Post by nikolas george »
Mate, that looks sooo good. You can also have a father and son picture like the one Armortek took at the tank museum recently :D :D .
Or maybe take yours to the tank museum and you can have grandfather, father and son !!
Have you got it running yet ?
Nik
Steve Norris
Has liked: 8 times
Hi Nik
The Elefant is a big impressive kit and will look great when running. I have tested the electrics in this one and everything works fine including the drive motors I just have not run it on the ground yet.
Has liked: 161 times
Been liked: 849 times
Any finished pictures of the Elephants? Perhaps outside? I always enjoy your finished outside images.
Steve Norris
Has liked: 8 times
Hi Robert
Unfortunately I did not get chance to get any shots outside as the weather was very bad and I needed to get both tanks to the packers.
This is about the best shot of one of the almost complete Elefants
And packed in a custom made case for shipping
Lucky customers to have your beautiful work! They look great!
B
Dave Jones
Been liked: 22 times
Post by Dave Jones »
Steve, hope you don't mind but I'm looking for a bit of advice.
I have just finished building the lower hull, all looks good except I have a gap between CR102 Upper Front plate and CR104 Hull Plate (see photo). Did you encounter this or have I simply run out of talent and got something upside down or back to front?
Appreciate your thoughts.
Thanks.
Dave
Lower Hull.jpg (81.88 KiB) Viewed 6137 times
Chang
Post by Chang »
Hi Dave,
I think this gap is there for every builder. Mine has got it. I simply fill it with car filler. Photos will be shown later.
Regards,
Lerh Chang
Dave Jones
Hi Chang
Thanks for the feedback. Out with the Milliput it is then. I'll fill the gap when I do the weld detail. I just wanted to make sure I hadn't done anything daft before I moved on too far.
Cheers!
Dave.
