Famo prototype build
Been liked: 3679 times
Assembly of the chassis started today .. already weights over 10kg !
Re: Famo prototype build
Forum permissions were not set properly for this section. Should be fixed now - everyone should have view access and members should be able to post.
Kian
Has liked: 2280 times
Been liked: 7192 times
What can I say?.....superb!
A couple of questions, are you able to fit the standard motor/gearbox units used for the Tigers and Panthers or are you putting together bespoke units dedicated to the Famo?
Also I'm presuming that the power required to run the Famo will be similar to say the Panther or maybe the KT?
Regards Phil.
@Phil,
The motors will be the normal drive motors with our high efficiency gearboxes.
Not sure what you mean by the power, but the torque from the gearboxes will be the similar to the King Tiger.
Kian
Just in case anyone thought we were joking when we said it would be a big kit ...
Front Tyres
Thanks for the reply Kian, ref the power, I'm not sure how you calculate the "power" or "torque" of such a model, running gear friction values, weight/mass to be moved etc but if it has the same available torque of the KT with less weight and so long as we can achieve traction (we may need to add ballast, just as the crews did in the field) the Famo model should have tremendous pulling power, I am looking forward to conducting some recovery trials of my own to establish just what this impressive model is capable of! All on VT of course.
Regards Phil.
Has liked: 158 times
Been liked: 830 times
Awesome! Great looking tires and chassis! This is an exciting addition.
Simon Peck
Has liked: 7 times
Been liked: 46 times
Post by Simon Peck »
Looking great so far! A question though: with similar torque to a King Tiger, which must have the widest track links of all the kits, will the Famo links be able to take the strain? Are they cast aluminium?
Robert Reid
Has liked: 99 times
Been liked: 446 times
Post by Robert Reid »
Ho.... Lee.... Smoke!
That is an amazing model.
But the real question is... will it tow a Rolls-Royce?
RPR
P.S. I think the more realistic question is... can a Rolls-Royce tow IT? What an amazing job, Armortek team!
Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Post by Brian Ostlind »
Looks like it belongs in my driveway... :D
Brian Ostlind
Simon Peck wrote:
Tue Jun 19, 2018 4:51 pm
I would think that the added grip of the rubber pads will be an equalizer!
Simon Peck
Has liked: 7 times
I meant will the links themselves be strong enough? Perhaps they are cnc’d steel?
Derek Attree
Has liked: 219 times
Been liked: 199 times
Post by Derek Attree »
Hi All
Been looking at this Famo idea since the start and was not convinced but I have to say
this looks stunning.
nearly big enough to get into, that will be some machine, the forum members will love that, regards simon.
