Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Post by Brian Ostlind »
Started actually building my Tiger one kit today. It is a 2017 Armortek Late Tiger 1.
here she is...does anyone know if the inside floor is red or white?
so far I have etch primed and added some red primer on top
Brian
Has liked: 161 times
Been liked: 830 times
Brian,
I think red oxide is fine for the floor. The crew compartment was a buff white. Engine and battery compartment are fine rust red.
Best regards Bob
Brian Ostlind
Robert E Morey wrote:
Mon May 21, 2018 2:27 am
Brian,
Best regards Bob
Cool, thanks.
Brian
Brian Ostlind
Brushed some of my automotive paint on. I’ll probably sand it down and re do it when I get a spray gun.
Brian Ostlind
FLOOR NO. 10 LATE TIGER 1 BUILD
I added red hull paint over the red primer on the floor and then gave it two coats of satin Humbrol enamel varnish. Here is a picture with the suspension bars on. Looks so good! does any one know how to polish the inside of the brass bushings? I got a little loctite in them when I set them.
Has liked: 792 times
You could try rubbing it with acetone (or your wife's nail polish remover) to soften it up and remove with a sharp implement.
Brian Ostlind
Prime time
Brian Ostlind
FINISH SANDING NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
ETCH PRIMER NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
Wheel assembly 2017 NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
Primer 2017 NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
Brian, unlike me, you are very organised and methodical.
Has liked: 2282 times
Been liked: 7196 times
Well Brian I had a tidy workshop one time, now I can't find anything, I can even lose a Tiger turret and not find it for days! :oops: I shall be watching your build with interest, regards Phil.
Brian Ostlind
Phil Woollard wrote:
Wed May 30, 2018 7:27 am
Tiger hide and seek?
