Tiger 1 (Early Variant) 2004 #98 build
Graham Hough
Been liked: 19 times
Re: Tiger 1 (Early Variant) 2004 #98 build
Post by Graham Hough »
Lubricants? Is it normal practice to lubricate the barrel inside the mantel and the turret ring? Something like graphited grease? All suggestions will be appreciated.
Has liked: 1484 times
Been liked: 1687 times
One thing to note is that a tank with a lubricated turret ring is very messy to work on, as you'll get the grease all over your hands, arms and sleeves when working inside the hull with the turret off.
BTDTRTS :roll:
Sam Hough
Has liked: 69 times
Been liked: 53 times
Post by Sam Hough »
The turret and deck arrived in Oxfordshire on Saturday. Messed up my electronics layout and track tension but Dad has done a great job.
Lots of work to do.
John Fitzsimons
Has liked: 6 times
Been liked: 812 times
Post by John Fitzsimons »
Well done. Very neat.
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Finally got the video camera pointing out of the drivers window (port?).
Could the Tiger 1 drivers actually see anything useful?
I managed to angle it down a bit but not much better.
NB Amp gauges not calibrated yet.
You get a few quick peeks in this video:
Yours looks about right. Love the HUD you have there.
Graham Hough
Looks good to me. Who is that handsome chap hiding behind the laptop ;)
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Thanks Adrian,
The video does make it pretty clear that visibility is very limited. Sounds like my "customer" is OK with it though.
Sam
Graham Hough
Just done a suspension rebuild in our Oxfordshire Depot and found the torsion bars next to the torsion arms were coming loose, has anyone considered brazing these parts together?
Has liked: 2282 times
Been liked: 7196 times
Hi Graham, absolutely not for brazing the torsion bars to the arms, the spring steel would lose its heat treated properties, and so you would have to attempt to get this back by heating and quenching with two dissimilar metals which is virtually impossible, you may have grub screws that hold the bars tight, these may have a taper/angle at the base, try grinding these flat to improve the contact area with the torsion bar regards Phil.
Graham Hough
Thanks Phil
I will follow your advice at the next rebuild.
Paul Wills
Has liked: 646 times
Been liked: 143 times
Post by Paul Wills »
Hi Both,
Have to agree with Phil on the torsion bars to the arms, grinding the point off the grub screw is the way to go.
Like the Video cameras, I remember trying to drive my Tiger just using the camera feed to my phone from the drivers vision slot, no chance. you can have quite a lot of fun with those Cmos Cameras!
https://www.youtube.com/watch?v=ZTd98OpucWM
Paul. :wink:
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Some visible "progress" after long slog with electronics and software.
I've not done modelling using a lump hammer before :)
Not helped Dad's paintwork, working up the courage to do the new bend and grind off the sides to match.
Sam
Sam Hough
Has liked: 69 times
Post by Sam Hough »
Turns out my Dad was right and very difficult to bend without the right tools. So doing what Steve Stuart suggested a couple of years ago and making from aluminium.
Steve Stuart
Has liked: 264 times
Been liked: 195 times
Post by Steve Stuart »
At a show last weekend I was rueing the selling of my old Turret "Lid" as it would have made a good tea tray for carrying cups back for everyone from the Catering Van :roll: Steve
