cable drums & storage boxes
- Has liked: 20 times
- Been liked: 737 times
As there are four sets of drums and boxes on the bogie's, any improvements made however small turn into quite a labour, the brackets holding the drums should be of a box section, and have opening quick release bearings; also the sides of the cable drums are dished outwards, and should be flat so they can lock in place, I had a go tonight to see if I could make a working hinged drum bracket with a sprung loaded lever, its fiddly but can be done, only problem 7 more to do
regards
Jeff
regards
Jeff
- Has liked: 4 times
Hi Jeff
super detailing again, I've been working on the drums for a few weeks now on and off and in the end just attached dummy levers to the brackets. I've had fun with the electrical cables though and have had difficulty getting a feel for the true size of them. In the end I have gone for a maplins special which look about right for the size of the drum etc.
Colin
Colin
Hi Collin, its good to hear from you, we seem to be at the same place on the build, I started to cut the levers last night, only managed 6, out of 16, but cut all the brass blocks for the drum brackets, I think it will take about a month to finish the drums, I managed to find loads of small springs, that will fit most of the sprung levers on the model, you are more than welcome to some
regards
Jeff
regards
Jeff
Hello Jeff
thanks for the offer of the springs. I will be in touch shortly regarding a visit to Northampton to look at your superb work. I filed my levels out of aluminium sheet, drillinmg the hole first and then working around it. They took ages so I limited the work to a couple each evening. I do not know how you manage to get all the levers working off tiny springs. You must be very dextrous. My fingers are like sausages and I find it difficult to work at such a relatively small scale.
I'll bring one of my bogies and the cruciform with me when I visit.
Still very green with envy best regards
Colin
Colin
- Been liked: 177 times
Hi Jeff
Excellent work, as usual.
I took these pictures today while visiting Jacques Littlefield's collection and though maybe there's a view of something you don't have. Doubtful, I know, but I thought I'd post them anyways. In hindsight, I'm sorry I didn't take more.
If I didn't know better, I'd say these pictures were of your 88.
Hi Tim, thanks for thinking of me, the pictures are great, not sure if I would attempt the optical sight, the only piece that I am having trouble working out what it does, are the flat sided posts / levers that are joined together and stored on the opposite side to the gun leaning rods, above the pry-bar, the only 88 I have seen them on is on Vince's pictures at Saumur, I was wondering if they were used to remove the cable drums, and with one each side to act as a ramp, if there is anybody with any info I would be most grateful, it looks like it is made from 6 pieces of metal, about 4-5 feet long, and clamped together, 3 up 3 down in a mirrored configuration,
regards
Jeff
regards
Jeff
- Been liked: 10 times
What can I say, the work on the boxes is amazing, and to make your own hinges as well !!! I'm about ready to put some decals on the Sherman but have been fighting witht he scanner today. I can't push the reesolution enough to increase the size by 6 times without loosing too much resolution.
Allan Richards
- Been liked: 1633 times
Jeff,
I find these decals a real pain and hate doing them. I've got some of the stars from "John's Stuff" I was trying to scan in some 1/35th decals and scale them up but despite spraying varnish over the ink jet print it still ran when put in water - no good at all !!! I will try again.
I've never had much success with stencils.
Allan Richards
