Can you use a FUTABA SKYSPORT 6 Radio Transmitter or do you have to use special transmitter for tanks -- if so where do you get one,
and how much do they cost?
Advice would be appreciated.
Colin Cahalin
technical question- PantherA
- Has liked: 1024 times
- Been liked: 2094 times
Re: technical question- PantherA
Colin
The legal answer is no. The FUTABA SKYSPORT 6 is, I believe, supplied with a 35mHz operating band, which in UK at least is restricted to airborne models. The 40 MHz band is allocated to surface models. Both frequency bands are only used on legacy systems which are very prone to interference and would also be subject to strict frequency control at any public display. Modern systems use 2.4Ghz and are protected against interference.
There is a comprehensive guide to selecting a radio in the Knowledge Base, here:
http://www.armortek.co.uk/Forum3b/viewt ... =34&t=6139
If you have other technical questions, Forum members will always try to help but it might save you trouble if you look for answers first in the Knowledge Base.
HELP ~~ CANNOT GET ELEVATION OF BARREL TO WORK. IT KEEPS GOING DOWN AND STOPPING DOWN AND RECOIL SERVO DOESN'T WORK AT ALL.
I'M USING A FUTABA SKYSPORT 6 TRANSMITTER AND 8 CHANNELS FUTABA RECEIVER ON 35.140 mhz.
DOES ANY ARMORTEK OWNER LIVE NEAR BISHOPS WALTHAM NR. SOUTHAMPTON, HAMPSHIRE THAT CAN HELP PLEASE.
THANKING YOU.
COLIN CAHALIN
THANKING YOU.
COLIN CAHALIN
- Has liked: 1421 times
- Been liked: 1603 times
Armortek are only in Otterbourne - probably closer than any of the owners !!
- Has liked: 2508 times
- Been liked: 443 times
Colin, the 35mhz radio you are using on your tank is illegal this is for aircraft only, you should remove this and replace with either a 40mhz or a 2.4ghz radio that is all the advice that can be givenColin Cahalin wrote: ↑Fri Sep 08, 2017 3:58 pmHELP ~~
