2016 Armortek audio system speaker question
John Grima
Been liked: 48 times
Post by John Grima »
While working on two tigers (an 2004, and 2016 early) Both of these models are using the current 2016 audio / electric motion package. I see on the module that there are only outputs for one speaker. Is this system designed for one speaker, or are the two speakers patched into the same output?
I.E. Red to Red, Black to Black?
yves mouton
Been liked: 741 times
Re: 2016 Armortek audio system speaker question
Post by yves mouton »
Hello John,
the wires for the speakers are two pairs of yellow and green ( for both speakers )
Regards Yves
Has liked: 2282 times
Been liked: 7196 times
Hi John , you will need to wire two of the Armortek/Tanoy speakers (or similar ohms value) in series using the single twisted pair, observe the polarity regards Phil
Has liked: 1492 times
Been liked: 1699 times
Both the Benedini and the amplifier are mono, so only one set of speaker connections.
You can wire two in parallel but watch the overall impedance.
Adrian
John Grima
Thanks guys, was a great help
yves mouton
Hello,
Hi John, i just see that the new Armortek sound module have only
two wires for the speakers, one green and one yellow ( older module have 2 pairs of wires ).
Adrian: so you have to connect the yellow and green wire to one of the speakers?
And put a separate wire between the two speakers ( connect - to - and + to + )
is that correct?
Is that also correct that there are only 2 modules now in the option packs?
I have only the sound and motion mudule.
Regards Yves
Yes
is that correct?
Yes
Yes :-)
yves mouton
Hello,
Thanks to confirm this Adrian.
regards Yves
